Kết quả 1 tới 7 của 7
    Thành viên mới cochan's Avatar
    Mar 2008
    Mặc định xin giúp cái log 6085
    JAF version 1.98.62
    Detected PKEY: 9000DA9A
    Card life counter: 99.99%
    JAF DCT4/BB5 LOADERS DIR: D:\Program Files\ODEON\JAF\Flash\
    JAF DCT4/BB5 PRODUCT DIR: D:\Program Files\Nokia\Phoenix\Products\
    JAF USB LOADERS DIR: D:\Program Files\ODEON\JAF\FlashUSB\
    JAF DCT3/DCTL LOADERS DIR: D:\Program Files\ODEON\JAF\Flash3\
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.26
    16-03-07
    RM-198
    (c) Nokia.
    HW version: 1403
    PCI version:
    RFIC version: 17211721
    DSP version: pb06w14v42.1
    PPM version: V 04.26
    16-03-07
    RM-198
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.0
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: v
    V 04.26
    16-03-07
    RM-198
    (c) Nokia.
    Production serial number: DCJ422363
    Product code: 0538776
    Module code:
    Basic production code: 0531926
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358061012129185
    IMEI spare to net: 3A 85 60 01 21 21 19 08
    IMEI SV to net: 33 85 60 01 21 21 19 18 F6
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file D:\Program Files\ODEON\JAF\JAF_RM-198.ini
    Setting local mode...
    Reading product code...
    Product Code: 0538776
    Checking path: D:\Program Files\Nokia\Phoenix\Products\RM-198\
    Checking path: \Products\RM-198\
    No ini files found...
    Done!
    Reading...
    16-03-07
    RM-198
    (c) Nokia.
    HW version: 1403
    PCI version:
    16-03-07
    RM-198
    (c) Nokia.
    V
    Retu version: 32
    Tahvo version: 53
    V 04.26
    16-03-07
    RM-198
    (c) Nokia.
    Module code:
    Flash code:
    Order number:
    Long production SN:
    ATO:
    Default SN type:
    LOCK STATUS:
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Checking path: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\
    Scanning ini files...
    MCU Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.mcusw.bin
    PPM Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.ppm_v
    CNT Flash file: D:\Program Files\Common Files\Nokia\DataPackage\Products\RM-198\rm198__05.03.image_v
    Languages in ppm: English,Vietnamese,Chinese S,Chinese T
    Done!
    Backing up CRT data...
    Setting FLASH MODE
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 002F0001 <=> SPANSION -> 72NS256N
    CMT Loader: D:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Reading CMT NPC certificate...
    Reading CMT VARIANT certificate...
    VARIANT CRT empty, skip save...
    Reading CMT CCC certificate...
    Reading CMT HWC certificate...
    Saved to D:\Program Files\ODEON\JAF\ProgData\35806101212918_CRT_backup _1759263.rpl
    Backup CRT OK!
    Backing up SIMLOCK data...
    Reading IMEI...
    D:\Program Files\ODEON\JAF\ProgData\358061012129185_CRT_backu p_181263.pm
    Done!
    Backup LCK OK!
    Reading SW version...04.26
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 0D10011470D66C56CA1891AA5A0716422AEFD73D
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: D:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    CMT Boot Ready
    CMT Loader Ready
    Operation took 0 minutes 8 seconds...
    No convertion block detected or file already converted.
    Erasing...
    Operation took 1 minutes 15 seconds...
    Writing...
    Stage 1
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT PUB KEYS...
    Sending CMT HASH for DSP0
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Sending CMT HASH for PASUBTOC
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for MCUSW
    CMD ID: 0x54
    Error write...
    Thành viên tích cực v&tmobile's Avatar
    Oct 2008
    Ctythegioididong
    kiếm cái ver cao chuẩn + bỏ vào HwK sẽ bảo đảm nhất ! trường hợp Flash ko hết khả năng bạn phải làm tới CPU.
    Thành viên chính thức phamkynam1's Avatar
    log bình thường mà bạn. kiếm ver chuẩn chạy lại đi
    Oct 2007
    Kiên Giang
    tìm ver chuẩn, cáp chuẩn chạy lại xem thế nào rồi hãy xử phần cứng
    Mar 2008
    flash ver cao rồi mà không đc..đang flash tự nhiên báo Wie không đc..
    để mình thử flash ver cao xem sao...thanks mấy pác nha
    Thành viên tích cực tranthao's Avatar
    Dec 2008
    bạn chạy bàng cáp gì vậy lấy cáp đa năng chạy cho good
    Thành viên mới thanhcongmobile_9x's Avatar
    Mar 2010
    ban thử bỏ 2 dấu backup đi sau đó rùi chạy lại sem nhé
    học hỏi và học hỏi cho nó giỏ : yahoo thanhcong_9xpro : chuyên đập phá mobile chất lượng có bảo hành
  1. 6085 cần giúp
    By mainhancon in forum BB5
    Trả lời: 17
    Bài viết cuối: 29-11-2010, 09:10
  2. 6085 cẩn giúp đỏ
    By nampro in forum BB5
    Bài viết cuối: 18-10-2010, 20:23
  3. 6085 xin giúp
    By hotboy3333 in forum BB5
    Bài viết cuối: 11-12-2009, 07:47
  4. 6085 màn hình cần giúp
    By n0t.0nline in forum BB5
    Trả lời: 14
    Bài viết cuối: 05-04-2009, 14:23
