test thử cái sim khác.ko được câu R sim, hàn lại chân ổ sim, hàn thêm 1 con tụ vào đường Vsim.
CMT Boot Data:
Asic ID: 000000010000022600010006010C192101001101
Asic Mode ID: 00
Asic EM ID: 00000353
Asic Public ID: 1E000217C0D00352E9EB985621C433057F0BABF2
HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
ROM ID: 191EC665DFAAF68F
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Flash ID: 881C0020 <=> ST -> M39L0R807
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Done!
Restarting phone...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 07.21
05-11-08
RM-237
(c) Nokia.
HW version: 2001
PCI version:
RFIC version: 17211721
DSP version:
ICPR61_08w10
PPM version: V 07.21
05-11-08
RM-237
(c) Nokia.
V
BT MCM version: 06cc-P9.1
Retu version: 32
Tahvo version: 53
Content Pack version: Content: v
V 07.21
13-01-09
RM-237
(c) Nokia.
Production serial number: 7F1090829
Product code: 0514949
Module code: 0203291
Basic production code: 0542523
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 356974017489705
IMEI spare to net: 3A 65 79 04 71 84 79 00
IMEI SV to net: 33 65 79 04 71 84 79 20 F5
LOCK STATUS:
CONFIG KEY: 0000000000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
Setting local mode...
Reading product code...
Product Code: 0514949
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-237\
No ini files found...
Done!
e chỉ có jaf thôi log cua em nó đây .giờ ko thấy nó báo đăng ký thẻ sim nưa nhưng máy lại ko có sóng
SỐNG TRÊN ĐỜI PHẢI CÓ CHỮ TÂM .DTDD :0922972486
MUỐN THÀNH CÔNG PHẢI CÓ CHỮ NHẪN....yahoo nguyenquang_201086
e thao ra lắp vào lại được 1cootj sóng viettel gọi thì ko đựoc báo lõi kết nối và sóng rất yếu .để sóng lên được 2 vạch thì gọi được ACE giúp e vói
thanks tất cả ACE đã nhiệt tình em đã làm ok rùi câu lại ic sim vạy là ok
bạn thử câu xem nào ko thì làm con retu là ok
DTDD&MVT DUY HOA
0979 193 779 - 097 888 38 15 - 0500 65 61 178
bạn thử thay sim khác đi xem nào . hôm qua mình vừa làm 1 em ko nhận thẻ nhớ song lắp vào bị ko đăng ký thẻ sim .lắp sim khac ok .
thay vi thay ic sim ban noi day ic sim di cho no chac di ban chu dong do it bi cac con khac cho lam
kẹp nguồn ngoài xem có nhận sim không nhiều khi tại pin đó.
bạn bỏ ic sim đi và cho em nó sợi dây đồng là ok liền
người đàn ông thiết thực là người đàn ông khi bước vào cây xăng giám hét to 2 tiếng " ĐẦY BÌNH "
