Kết quả 1 tới 10 của 11
    Thành viên mới hoangfones11's Avatar
    Apr 2010
    Mặc định 5200 bi contactsensive cần ae giúp !
    nhờ ae giúp cây 5200 bi contactsensive này với e đã fhash rồi mà ko đc phần mềm em còn gà làm nhờ ae chỉ giáo thêm :
    log ne:
    JAF version 1.98.62
    Detected PKEY: 90009B6C
    Card life counter: 99.99%
    USB Cable Driver version: 7.0.2.0
    Changing mode...Done!
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 19000214B1C36E56588DC2477426F4824D701FE8
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 220800EC <=> SAMSUNG (SEC) -> K8F5615ETM/K5G5629ATD
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.20
    23-10-08
    RM-174
    (c) Nokia.
    HW version: 2000
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.20
    23-10-08
    RM-174
    (c) Nokia.
    A
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Content Pack version: Content: a
    V 07.20
    13-01-09
    RM-174
    (c) Nokia.
    Production serial number: DLJ749490
    Product code: 0541045
    Module code: 0203053
    Basic production code: 0530542
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 358659014357819
    IMEI spare to net: 3A 85 56 09 41 53 87 01
    IMEI SV to net: 33 85 56 09 41 53 87 21 F3
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    Provider: AT&T;U.S.A. (3650)
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-174.ini
    Setting local mode...
    Reading product code...
    Product Code: 0541045
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-174\
    Checking path: \Products\RM-174\
    No ini files found...
    Done!
    V.I.P hoanglanhpromobile's Avatar
    Jul 2008
    korea
    bạn có MXkey hay thiết bị nào sx4 dc thì mang wa làm . con jaf không giải quyết dc vấn đề này . nếu có MX key thì repair simlock - repair SD - SUPER SD auth - nạp pm [1] va [309] - ok . chúc thành công . thân
  3. ( hoanglanhpromobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    hoangfones11 (25-07-2010)
    Thành viên mới mis thang's Avatar
    mình nhìn log bằng jaf thì log binnh thường bị phần cứng thui bạn có mx-ky không cho xem log bằng mky luôn
  5. ( mis thang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên tích cực ngocquy_mobile's Avatar
    Mar 2006
    Quất Lâm beach
    sx4 với mxkey....rồi write full pm nếu not ok thì check HW.
    ĐỪNG HỎI VÌ SAO ANH YÊU EM - 0949.106.106-Y/h: comeback_tome2004vn
  7. ( ngocquy_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #5
    V.I.P TânĐạiDương's Avatar
    Jan 2007
    59A QL 13-HBP-Thủ Đức-TP.HCM
    máy khởi động lên báo ctsv hay xác nhận máy xong mới bị ctsv ?
    Nhận Bẻ Khóa -Sữa ĐTDĐ Lấy Liền-Nạp Tiếng Việt Sửa Lỗi,Nâng Cấp Phần mềm-389/1A-QL 13-Hiệp Bình Phước-Q.Thủ Đức-TP.HCM-0909445774
  9. ( TânĐạiDương ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #6
    Apr 2010
    Trích Được post bởi anhduongvn Xem bài viết
    bỏ sim vào thì lên chữ contactsensive luôn còn bỏ sim ra thì nhấn khởi động máy mới bị . em chỉ có hộp jaf thôi mấy anh ơi giúp em với . thanks
  11. #7
    Thành viên chính thức chihuongmobil's Avatar
    bạn có MXkey hay thiết bị nào sx4 dc thì mang wa làm . con jaf không giải quyết dc vấn đề này . nếu có MX key thì repair simlock - repair SD - SUPER SD auth - nạp pm [1] va [309] - ok . chúc thành công //...làm như a này là đúng nè.nếu bạn kg có mx thì phài nhờ nơi khác thôi cố gắng bạn nhé
    CÁC BẠN LÀ THẦY CỦA TÔI
  12. #8
    Thành viên mới khanhquangmobile's Avatar
    Feb 2010
    nếu bạn ở Phú TÀi -Bình Định thì liên hệ với mình ,mình giúp cho giá rất hưu nghị
  13. #9
    Thành viên tích cực Ghost_Mobile™'s Avatar
    May 2010
    sơn tây
    Trích Được post bởi CON_ME_MAY_HOANG_THONG Xem bài viết
    giúp con mẹ mầy mầy chỉ là ăn cức mà thôi
    mod nhà mình đâu nhỉ .thô tục quá
    Chỉ có bia mới hiểu, Bụng mênh mông nhường nào Chỉ có bụng mới biết , Bia đi đâu về đâu
  14. #10
    Thành viên chính thức hoang_hai's Avatar
    Mar 2010
    TP bắc ninh
    sao lại có con người vô văn hóa như vậy thật sự sấu mặt anh em trong nghế mobile
  1. 5200 càn các bác giúp
    By thuadtth2010 in forum Sửa chữa phần cứng
    Bài viết cuối: 18-04-2010, 22:51
  2. 5200 cần giúp!
    By minhhaucv in forum BB5
    Bài viết cuối: 19-03-2010, 07:52
  3. giúp e con ic phím 5200 với
    By dungnv86 in forum BB5
    Bài viết cuối: 04-06-2009, 12:25
  4. ic phím 5200 cần giúp
    By blackeyexx in forum BB5
    Bài viết cuối: 09-04-2009, 15:10
  5. giúp đỡ sơ đồ 5200 !!!
    By viettel mobile in forum BB5
    Bài viết cuối: 08-11-2008, 13:06
