Kết quả 1 tới 3 của 3
    V.I.P ThanhHai_GSM's Avatar
    Mặc định 3110c nhờ anh em xem log flash
    máy khách dem đến bảo tự mất nguồn mình flash báo vậy đã thay cáp đa năng chuyển sang mxkey cũng vậy
    1ST BOOT : C0,07 [Rm-237] [2.1.0.1]
    RAPx ID : 000000010000022600010006010C192101001101
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    RAPx PBID : 22D000146EE87B56FBC693306B72A3E0C4E07A47
    RAPx MODE : 00
    RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
    RAPx ROID : 191EC665DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00898981-00006A21, Int NU48F256
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo_v1331.fg, Ver: 1.33.1
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm237__07.21.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00020000-0007FFFF
    CMT NOR Erase Area: 0x00080000-000DFFFF
    CMT NOR Erase Area: 0x00100000-001FFFFF
    CMT NOR Erase Area: 0x00200000-0031FFFF
    CMT NOR Erase Area: 0x00320000-0105FFFF
    CMT NOR Erase Area: 0x01060000-01067FFF
    CMT NOR Erase Area: 0x01068000-0107FFFF
    CMT FLASH ERASE OK, Time: 00:05
    CERT_BLK_ERROR at: 0xFFFFFFFF, 00
    ERR: CMT FLASH WRITE C_BLK 000000000000000910000000B172, LN: 0x000600, Time: 00:05
    còn đây là log flash mxkey
    Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
    Processing file: rm217__07.21.mcusw as MCU
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported RAP Ids: 0103192101001101, 010C192101001101
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 22D000146EE87B56FBC693306B72A3E0C4E07A47
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS is blank/erased.
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 1.047 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.156 s
    CMT NOR area [00020000-0007FFFF] erased in 1.078 s
    CMT NOR area [00080000-000DFFFF] erased in 0.187 s
    CMT NOR area [00100000-001FFFFF] erased in 0.328 s
    CMT NOR area [00200000-0031FFFF] erased in 0.360 s
    CMT NOR area [00320000-0105FFFF] erased in 3.141 s
    CMT NOR area [01060000-01067FFF] erased in 0.172 s
    CMT NOR area [01068000-0107FFFF] erased in 0.156 s
    Flash programming ...
    Error while programming [00] at 0xFFFFFFFF, Result: 0000
    Please try to use newer flashloader.
    Flashing terminated with error(s) in 45.922 s
    RX Buffer: B372
    up cái anh xem hộ mình
    Thành viên chính thức vovanvan's Avatar
    Oct 2009
    kiếm cáp zin ma thử lại nha bạn !
    liên hệ : timem_odau545@yahoo.com
    mobile : 0906675999
  1. 3110c flash báo lỗi
    By nobitathuan2 in forum BB5
    Trả lời: 11
    Bài viết cuối: 22-09-2011, 23:34
  2. 3110c FLASH không được
    By quyduong191 in forum BB5
    Bài viết cuối: 20-12-2010, 12:54
  3. 3110c đã flash đủ cách.
    By ♥Hùng—Mobile♥ in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 26-06-2010, 07:00
  4. 3110c Flash bị lỗi
    By inbox in forum BB5
    Trả lời: 20
    Bài viết cuối: 10-09-2009, 09:23
  5. N-box có Flash được 3110c ?
    By ducquynh in forum BB5
    Trả lời: 14
    Bài viết cuối: 01-07-2009, 23:27
