Kết quả 1 tới 10 của 13
    Thành viên tích cực ducmt49's Avatar
    Jul 2008
    Mỹ Tho.Tiền Giang
    Lightbulb N5610 RM-242 contacsever ! help me!
    Version from phone: 09.40
    Version from file: 09.40
    Library version: 1.0.0.8980(18-10-2010), 1.0.0.14844(18-10-2010)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 134000100AF40154276ED9D22809D86468DAA0DD
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    FlashID0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: NOR,CMT
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
    CMT PAPUBKEYS HASH: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB
    TransmissionMode: DDR&TX2
    Reading CMT NPC (0x168 bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0x160 bytes).
    Reading CMT HWC (0xD4 bytes).
    Flash Imei: 35865201145468
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35865201145468_BA CK.rpl"
    Processing MCU file: rm242__09.40.mcusw
    [BB5,BB5 ALGORITHM] size: 20.36 MB
    Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 21.87 MB
    CMT NOR area [00000000-0001FFFF] erased in 0.516 s
    CMT NOR area [00040000-000BFFFF] erased in 1.422 s
    CMT NOR area [000C0000-0013FFFF] erased in 0.329 s
    CMT NOR area [01480000-015FFFFF] erased in 3.938 s
    CMT NOR area [00140000-0147FFFF] erased in 47.515 s
    Flash programming ...
    CMT PAPUBKEYS: EE7EB2973C70788F43BFADFB1AD46A77E51DF8DB (RAP Certificate 83 v1) written.
    Programming completed in 11 min 45.578 s
    Processing PPM file: rm242__09.40.ppm_blue_v
    [BB5,BB5 ALGORITHM] size: 6.33 MB
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 6.75 MB
    CMT NOR area [01600000-01CBFFFF] erased in 16.078 s
    Programming completed in 3 min 46.203 s
    Processing CNT file: rm242__09.40_ISM_004.image_white_v_no_yahoo
    [BB5,BB5 ALGORITHM] page size: 128 K size: 17.52 MB
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Erase size: 34.87 MB
    CMT NOR area [01FC0000-03F9FFFF] erased in 1 min 3.719 s
    CMT NOR area [01CC0000-01FBFFFF] erased in 7.563 s
    Converting UCP blocks to 128 K.
    Programming completed in 10 min 38.547 s
    Total time for flashing process(boot+erase+write) was 30 min 29.391 s
    Flashing completed in 32 min 4.921 s
    After Flash Processing ...
    Updating Product Code OK.
    Reseting Warranty And LifeTimer OK.
    Reseting Factory Values OK.
    Phone Type: RM-242 (Nokia 5610d-1)
    SW Version: V 09.40 07-11-08 RM-242 (c) Nokia
    Imei plain: 35865201145468-9
    Product Code: 0552248
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY[MX] seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 358652011454689
    Version: SIMLOCK SERVER
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    UFS3 SarasSoft disconnected.
    log của em nó!
    Technical Assistance GIALAI_GSM's Avatar
    Dec 2009
    GIALAI
    sx4 witer pm 1 và 309 là ok thôi. ( nếu vẫn không được thì tiến trình sửa rpl trường hợp này thì ít )
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Jul 2008
    Mỹ Tho.Tiền Giang
    CMT Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Original Imei: 35865201145468
    Original Product code: 0552248
    Bluetooth ID: 001E3A6D002C
    SW Version: V 10.00 06-03-09 RM-242 (c) Nokia
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    Jul 2008
    Mỹ Tho.Tiền Giang
    xin hướng dẫn cụ thể giúp em!
    Jul 2008
    Mỹ Tho.Tiền Giang
    chỉ em nạp -sx4 witer pm 1 và 309
    Dec 2009
    GIALAI
    search lại bài cũ hoặc download cái video này về tham khảo
    mobile services
    NHƯ HẠ
    yahoo: gialai_gsm
    Jul 2008
    Mỹ Tho.Tiền Giang
    ok ! để em xem! thankS>>
    Jul 2008
    Mỹ Tho.Tiền Giang
    cho em hỏi cái file pm 309 làm sao có anh!?
    V.I.P hoanglanhpromobile's Avatar
    Jul 2008
    korea
    Trích Được post bởi ducmt49 Xem bài viết
    load cái pm full . rùi xóa hết đi chỉ để lại 1 - 309 là được chứ gì .
    hãy nhấn nút THANKS khi bài viết hữu ích cho bạn . thank all
    Jul 2008
    Mỹ Tho.Tiền Giang
    có pm full con này cho em đi
  1. Trả lời: 6
    Bài viết cuối: 12-12-2012, 21:56
  2. giúp em N5610 không nhận tai nghe
    By cuongfone in forum BB5
    Bài viết cuối: 20-07-2010, 12:38
  3. câu nút nguồn n5610
    By thienthanhmobile in forum DCT3-DCTL
    Bài viết cuối: 19-07-2009, 17:04
  4. Trả lời: 6
    Bài viết cuối: 13-06-2009, 17:45
  5. N5610 mo len nguo roi tắt
    By lonanxi in forum BB5
    Bài viết cuối: 12-06-2009, 16:59
