Để chạy lại rồi thử xem, không được thì log tiếp nha ae@ Thanks
dùng USB mà múc cho e nó mau tỉnh
unlock all mobile yahoo:quangdung54@ymail.com
Nó cũng chả lên
Log đây:
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED!!!
USB Cable Driver version: 7.1.29.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Detected P-KEY: 90009699
Init usb communication...
Phone Type:
Searching for phone...Detected P-KEY: 90009699
Not found!!!
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-240\
Checking path: \Products\RM-240\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.mcusw
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.ppm_t
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00_ISM_006.image_t_au_brown
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Backing up CRT...
Reading IMEI...
Failed! Aborting!
Failed to backup CRT...
Preparing for downgrade...
Failed to prepare for downgrade...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 06.02.002
Elf2flash 07.14.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
...................Loader Sent!
Stage 2 starting.......................................... .................................Loader Sent!
Stage 3 starting..................Phone prepared OK!
Waiting for the phone to boot...
Status byte: 0400
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 2451, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.mcusw...
Erasing cmt zone 00000000 - 0001FFFF ... Erase result: 0000
Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
Erasing cmt zone 01480000 - 015FFFFF ... Erase result: 0000
Erasing cmt zone 00140000 - 0147FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00.ppm_t...
Erasing cmt zone 01600000 - 01CBFFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-240\rm240__10.00_ISM_006.image_t_au_brown...
Erasing cmt zone 01FC0000 - 03F9FFFF ... Erase result: 0000
Erasing cmt zone 01CC0000 - 01FBFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for NOLO
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for UPDAPP
Sending CMT HASH for DSP0
Sending CMT HASH for MCUSW
Rebooting...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
Phone not found...
Done!
Lên bình thường rồi. Cài lại Win là OK! Thanks các anh
