giúp em log con w850i
v0.915039/UNI
CARD SERIAL: 00102641
Loaded 51 flash descriptors
SIGNED MODE (USING SERVER)
CFG:10001000000000
ChipID:9900,EMP protocol:0301
PHONE STATE: "RETAIL"
FLASH CID: 0052
Speed:921600
OTP: LOCKED:1 CID:49 PAF:1 IMEI:35240101576946 CERT:RED
FLASH CID:52 COLOR:RED
PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0
LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005
Flash ID check:2019
Flash props sent ok
writing "E:\BOX setup\setool3\w850\New Folder (2)\R1JG001_FS_APAC_CY_RED_CID52.ssw"
CURRENT FLASH FILE CID:52
SSW uses full hash, hash len is: 5140
Will flash 257 blocks...
SSW loading returns:0
LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
loader startup: executed
loader GDFS startup: executed
loader filesystem startup: executed
loader unlock: executed
using GENERIC phone customization
tpa/preset/custom/C3_PCA_G3v2.cer
tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm
tpa/preset/custom/customize.xml
tpa/preset/custom/DESKTOP_HOOK_2.itm
tpa/preset/custom/Entrust.net Root Certificate.cer
tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt
tpa/preset/custom/FM_PICTURES_HOOK_3.itm
tpa/preset/custom/FM_SOUNDS_HOOK_3.itm
tpa/preset/custom/FM_THEMES_HOOK_3.itm
tpa/preset/custom/FM_VIDEOS_HOOK_3.itm
tpa/preset/custom/GAMES_HOOK_3.itm
tpa/preset/custom/GTE_CyberTrust_Root.cer
tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt
tpa/preset/custom/Root.cer
tpa/preset/custom/SEMC_E2E_Root_CA.crt
tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm
tpa/preset/custom/ThawtePremium.der
tpa/preset/custom/ThawteServerCA.cer
tpa/preset/custom/Utiroot.cer
tpa/preset/custom/VeriSignClass3Root.cer
tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt
Phone detached
Elapsed: 170 secs.
CFG:10001000000000
FLASH CID: 0052
Speed:921600
packet not acknowledged (3C)
can't get packet start.
ldr_on_ldr payload error (00)
Elapsed: 67 secs.
CFG:10001000000000
FLASH CID: 0052
Speed:921600
llbug: blk write fail. fatal
payload block 43 NAK
Elapsed: 36 secs.
hiện tái máy không lên nguồn
anh nào biết chạy files nào chuẩn chỉ giúp em với
