Trang 6 của 17 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 ... CuốiCuối
Kết quả 51 tới 60 của 167
  1. #51
    Jan 2007
    NCK Dongle / Pro Dongle SPRD Module v1.4 Update Released - [10/01/2021]
    Added:
    Lava
    Atom 2X - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    LE9920 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    LH9810 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    LH9910 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    LN9820 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    LN9821 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    X11 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    X41 Plus - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    Z40 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    Z51 - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    Alcatel
    OT-3080 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    OT-3088 (beta) - Reset FRP/Wipe/Factory Reset/Backup & Restore NVRam/Miscata/Prodnv/Write PAC File/Simunlock (beta).
    Supported/Added for direct selection in exe next cpu
    • SC7720EA_EMMC
    • SC7731G_EMMC 5.x
    • SC7731C_EMMC
    • SC7731CA_EMMC
    • SC9863A_EMMC
    • SC7731E_EMMC
    • SC9832A_EMMC
    • SC9832E_EMMC
    • SC9850K_EMMC
    • SC9830_EMMC 4.x
    • SC9830A_EMMC
    If generic loader not work (this can happen in new phones if loader sign key differ), user must use custom loader generated from pac firmware.
    - Added phrasing for DHTB header on new CPU, this will allow to display more detailed info about cpu.
    - Added fastboot functions in exe.
    - Added unlock bootloader in fastboot mode new generation cpu.
    This method is based on leaked rsa key and support many phones.
    But will not work for all phones, if phone firmware have different sign key, metod will not work.
    1. Read info(token id)
    2. Generate signature file using leaked rsa4096_vbmeta.pem key(need_files directory)
    On this step user will select private key, and exe will prompt to default one.
    Can be selected other private key if user have it and it's supported by phone
    3. Sending generated signature in phone.
    On some models this function will work, on some not(key differ)
    If your phone not accept generated by exe signature, user can request this file officially and send in phone using exe.
    Exe allow to select key file, if user have private key from firmware source, he can use own key.
    Tested on alcatel ot-5024, Xiaomi Qin 2, posible will work in other phones.
    -- Locked Bootloader.
    --- Erase FRP in fastboot mode(need unlocked bootloader)
    - Added support for new pac format (old exe gived exception on this)
    Exe will autodetect pac format and will use new or old layout auto.
    - Added simunlock in flash mode for supported phones.
    Many phones after unlock in diag mode relock after factory reset, so this will help to solve problem.
    - Added simunlock support for phones with new security, so called type 4
    This is beta version, if some not work, will need to provide nvram backup maked by this exe version.
    Backups maked by old exe versions is not compatible with this.
    Unlock is supported in diag mode and flash mode.
    Unlock will work only on phones with not damaged security.
    Phones with erased or rewrited from other phone nvram will not work.
    Website:
    www.nckdongle.com
    Download From Support Area
    OR
    MediaFire
    https://www.mediafire.com/file/w5hbs...r_1_4.rar/file
    Google Drive
    https://drive.google.com/file/d/1vTZ...ew?usp=sharing
  2. #52
    Jan 2007
    Ultimate NCK Huawei Main Module v370 & Flasher v153 - [13/01/2021]
    What is new:
    New features and functions by TESTPOINT:
    Huawei Mate 20, P30, Pro, Lite & much more...
    Kirin659
    Repair: IMEI (certificate required)/ PCBsn/ MAC/ BT/ THEME Color / Vendor/ Country/ Model /SIMCARD Mode.
    Unlock: Network Sim Lock/ Bootloader/ FRP
    Read: Bootloader unlock code.
    Kirin710
    Repair: IMEI (certificate required)/ PCBsn/ MAC/ BT/ THEME color / Vendor/ Country/ Model.
    Kirin950
    Repair: IMEI (certificate required)/ PCBsn/ MAC/ BT/ THEME Color / Vendor/ Country/ Model.
    Kirin955
    Kirin960
    Repair: IMEI (certificate required)/ PCBsn/ MAC/ BT/ THEME color / Vendor/ Country/ Model /SIMCARD Mode.
    Unlock: Network Sim Lock/ FRP
    Kirin970
    Kirin980
    Repair: IMEI (certificate required)/ PCBsn/ MAC/ BT/ THEME Color.
    Ultimate NCK Huawei & Flasher v153
    New functions and features added:
    - Function to enable/disable testpoint mode via software.
    - FRP unlock feature by update or testpoint mode.
    - Function to load or temporary unlock bootloader.
    - Function to read phone information.
    - Partition reading feature.
    NCK Box & Dongle
    https://forum.gsmhosting.com/vbb/f82.../#post14306434
    UMT / Avengers
    https://forum.gsmhosting.com/vbb/f97.../#post14306436
  3. #53
    Jan 2007
    NCK Dongle / Pro SPRD Module v1.5 Update Released - [03/02/2021]
    Added Repair IMEI in flash mode (for supported android phones)
    Added Repair IMEI for phones with type 4 security
    -- Repair is supported in diagnostic or flash mode.
    --- Detection is auto, need just to fill imei and select what IMEI need to write.
    ---- Software will select auto new or old security.
    ----- Phones with damaged or erased security will not work.
    Improved custom loader detection, using custom loader can be serviced most spreadtrum/unisoc cpu now, even if cpu is not listed.
    Added:
    Archos
    Archos Core 555 Ultra - Reset DRP/Factory Reset/Factory Format/Repair IMEI/Sim Unlock/Write Firmware/Backup & Restore NVRAM
    Mobicel
    mobicel RIO SS - Reset DRP/Factory Reset/Factory Format/Repair IMEI/Sim Unlock/Write Firmware/Backup & Restore NVRAM
    MEIZU
    MEIZU C9 M818H (SC9832E) select generic - Reset DRP/Factory Reset/Factory Format/Repair IMEI/Sim Unlock/Write Firmware/Backup & Restore NVRAM
    Techno
    Tecno SC7S - Reset DRP/Factory Reset/Factory Format/Repair IMEI/Sim Unlock/Write Firmware/Backup & Restore NVRAM
    Improved restart phones in diagnostic mode for supported phones.
    Improved network unlock for type 4 security.
    Fixed bug with Repair IMEI in diagnostic mode for IMEI 3 and IMEI 4
    Official Website:
    www.nckdongle.com
    OR
    Google Drive
    https://drive.google.com/file/d/12L-...ew?usp=sharing
    OR
    MediaFire
    https://www.mediafire.com/file/hxtzg...aller.rar/file
  4. #54
    Jan 2007
    NCK Box / Pro SPRD Module v1.5 Update Released
    Added:
    Archos
    Mobicel
    MEIZU
    Techno
    Supported cpu sc7731e, sc9832e, sc9820e
    Official Website:
    www.nckdongle.com
  5. #55
    Jan 2007
    NCKDongle AndroidMTK 2.7.4
    Added oppo safe reset in meta mode.
    Tested phones was
    Oppo A31
    Oppo A12
    Oppo A1k
    Oppo Reno 2F
    OPPO F15
    Oppo RENO 2Z
    Oppo F11
    Oppo realme C2
    Oppo Realme C3
    Oppo realme C12
    Can be supported many other oppo models, function is safe and use phone api to perform reset.
    Function is located under (factory reset - format storge) tab.
    CDC driver is located in usb_driver directory, located in main exe directory.
    Undated exe to support 7.2033 dll version for latest cpu support.
    Added software testpoint function in exe.
    This function allow to connect secured phones as "generic".
    Phone must be connected in brom mode and execute function.
    To service phone in flash mode(frp, format, backup/restore security) need to load scatter+ preloader or preloader.
    Supported cpu for this function
    MT6735
    MT6737,
    MT6580,
    MT6739,
    MT6755,
    MT6757
    MT6763,
    MT6761
    MT6765
    MT6768
    MT6771
    MT6785
    MT8127
    MT8163
    MT8173
    MT8695
    MT6873
    MT6582
    MT6799
    This function is based on chaosmaster and xyzz work.
    To use this version libusb_win32 must be installed.
    With connected phone need to execute filter wisard.
    Do not execute inf file wisard, this will replace mtk drivers with libusb driver.
    Added load preloader, this function need to use to service phones in flash mode.
    Remaked exe gui.
    Please download installer from support, using main module.
    To download direct installer press here
  6. #56
    Jan 2007
    NCKBox AndroidMTK 2.9.4
    Tested phones was
    Oppo A31
    Oppo A12
    Oppo A1k
    Oppo Reno 2F
    OPPO F15
    Oppo RENO 2Z
    Oppo F11
    Oppo realme C2
    Oppo Realme C3
    Oppo realme C12
    MT6735
    MT6737,
    MT6580,
    MT6739,
    MT6755,
    MT6757
    MT6763,
    MT6761
    MT6765
    MT6768
    MT6771
    MT6785
    MT8127
    MT8163
    MT8173
    MT8695
    MT6873
    MT6582
    MT6799
    Remaked exe gui.
  7. #57
    Jan 2007
    Ultimate NCK Huawei Flasher v157 Update Released - [01/03/2021]
    Added:
    -Automatic check and update fastboot driver.
    -Timeout for flashing EXT4 partitions in fastboot mode increased
    -Other bugfixes and improvements.
    Other Module:
    new version added to autoupdate
    Fixed:
    Vendor Country repair over Xloader
    Kirin970 IMEI Repair over xloader ( error 197)
    Qualcomm FRP unlock.
    UMT Update Thread:
    https://forum.gsmhosting.com/vbb/f97...021-a-2951308/
    Avengers Update Thread:
    https://forum.gsmhosting.com/vbb/f82...021-a-2951305/
    NCK Box Update Thread :
    https://forum.gsmhosting.com/vbb/f80...021-a-2951306/
    NCK Dongle Update Thread:
    https://forum.gsmhosting.com/vbb/f82...021-a-2951307/
  8. #58
    Jan 2007
    NCK Dongle / Pro SPRD Module v1.6 Update Released
    - Added SimUnlock and repair imei for phones with SC9863A cpu
    Exe will autodetect type of security and will execute task.
    Supported flash mode and diag mode for this function.
    Will work only on phones with not damaged security(nvram).
    - Added SimUnlock and repair imei for phones with type 14 security
    Was reported on ITEL phones.
    - Added repair imei in flash mode for supported by exe android phones.
    Supported secured and not secured phones.
    - Improved custom loader opperations to allow more supported phones in exe.
    - Added more loaders for sc7731e and sc9863a based phones.
    - Improved diag mode opperations.
    Now exe will wait untill phone will restart in diag mode.
    For some phones this can take 10-20sec, for some phones is instant.
    Installer can be downloaded using main module as usual.
    For direct link click here
  9. #59
    Jan 2007
    NCK Box / Pro SPRD Module v1.6
    Installer can be downloaded from support using main module as usual.
  10. #60
    Jan 2007
    Ultimate NCK Huawei Module Update Released in Auto update - [02/04/2021]
    Added:
    For NCK Products / UMT Products / Avengers Box
    Kirin980
    Models:
    Huawei Honor Magic 2 - Vendor/Country/Model Repair - Demo Remove.
    Huawei Honor 20/Pro - Vendor/Country/Model Repair - Demo Remove.
    Huawei Honor V20 - Vendor/Country/Model Repair - Demo Remove.
    Huawei Mate 20/Pro/Premium - Vendor/Country/Model Repair - Demo Remove.
    Huawei Mate 20 RS Porsche Design - Vendor/Country/Model Repair - Demo Remove.
    Huawei Mate 20 X - Vendor/Country/Model Repair - Demo Remove.
    Huawei MediaPad M6 10.8 - Vendor/Country/Model Repair - Demo Remove.
    Huawei MediaPad M6 8.4 - Vendor/Country/Model Repair - Demo Remove.
    Huawei Nova 5 Pro - Vendor/Country/Model Repair - Demo Remove.
    Huawei Nova 5T/Premium - Vendor/Country/Model Repair - Demo Remove.
    Huawei P30/Pro/Premium - Vendor/Country/Model Repair - Demo Remove.
    Can Be serviced in software or hardware TP only.
    Fixed Bug in Qualcomm detection in manufacture mode.
    Kirin 659 bootloader code reading in TP fixed.
    This version does not need to be downloaded as it is already added in auto update from software.
Hiện có 11 người đang xem bài này . Bao gồm : 0 thành viên và 11 khách
