Trang 2 của 7 Đầu tiênĐầu tiên 1 2 3 4 5 6 7 CuốiCuối
Kết quả 11 tới 20 của 69
  1. #11
    Jan 2007
    [27/11/2019] GSM Shield Box Qualcomm Setup v1.2 is out...
    Supported Qualcomm Chipsets with AutoDetection:
    - MSM8909
    - MSM8x10
    - MSM8x26
    - MSM8916
    - MSM8917
    - MSM8920
    - MSM8929
    - MSM8936
    - MSM8937
    - MSM8952
    - MSM8953
    - MSM8960
    - MSM8974
    - MSM8976
    - MSM8992
    - MSM8994
    - MSM8996
    - MSM8998
    - SDM7xx
    - SDM8xx
    Supported Features:
    - Automatic Selection of programmer
    - Option to select custom programmer
    - Automatic Memory Type Detection
    - Device Identification Function
    - Read Factory Firmware
    - Write Factory Firmware
    - Support Multi Program Firmware Read/Write
    - Safe Flashing for Security Data Protection
    - Reset FRP in Flashing Process
    - Read/Write/Erase Any Partition
    - Backup/Restore/Erase Security
    - Reset FRP
    - Format Userdata
    - Safe Format Userdata
    - Supports Both IMEI Repair
    - Reset Vivo User Lock without Data Loss
    - Read QCN Data
    - Write QCN Data
    - Support for UFS Memory Devices
    - Xiaomi Mi Account Reset
    - Xiaomi Mi Account Relock Fix
    - Xiaomi Factory Reset in sideload
    Added:
    Huawei
    - Enjoy 8e (ATU-TL10)
    - Y6 (SCL-U31)
    - Y7 Prime 2019 (LDN-L21)
    Nokia
    - 3.2
    OnePlus
    - 6
    - 6T
    Oppo
    - A57t
    TP-Link
    - Neffos Y5i (TP804R)
    - Neffos Y5s (TP-804A)
    Vivo
    - Xplay 6
    Wiko
    - View2
    Xiaomi
    - BlackShark 1
    ZTE
    - Blade V9 VITA
    Xiaomi Mi Account Reset - EDL Mode
    - Reset Mi Account on Supported Xiaomi Devices
    - Devices with EDL Auth are not supported at the moment
    - If you get Wifi issue after reset, please flash persist
    Xiaomi Mi Account Relock Fix - ADB Mode
    - Must connect phone with USB debugging enabled
    Xiaomi Factory Reset - sideload
    - You can Format userdata using this function
    - To check only firmware details, click No when asked to proceed with factory reset
    Xiaomi IMEI Check
    - You can check phone details, warranty status etc using phone IMEI
    Download Control Panel Software HERE
  2. #12
    Jan 2007
    [30/11/2019] Gsm Shield MTK setup v1.2 is out
    Added
    Lenovo
    • K9 - FRP/Factory reset (flash and meta mode)/Backup & Restore nvram (flash and meta mode)/Repair IMEI/Write Firmware/Read info etc...
    • K5S - FRP/Factory reset (flash and meta mode)/Backup & Restore nvram (flash and meta mode)/Repair IMEI/Write Firmware/Read info etc...
    Itel
    • A15 - FRP/Factory reset (flash and meta mode)/Backup & Restore nvram (flash and meta mode)/Repair IMEI/Write Firmware/Read info etc...
    • A45 - FRP/Factory reset (flash and meta mode)/Backup & Restore nvram (flash and meta mode)/Repair IMEI/Write Firmware/Read info etc...
    Panasonic
    P101 - FRP/Factory reset (flash and meta mode)/Backup & Restore nvram (flash and meta mode)/Repair IMEI/Write Firmware/Read info etc...
    Alcatel - Added per user Request
    • OT-5059Y - Direct network unlock in flash mode/New & old security supported
    • U5A PLUS 4G - Direct network unlock in flash mode/New & old security supported
    • OT-5059D - Direct network unlock in flash mode/New & old security supported
    • OT-5059A - Direct network unlock in flash mode/New & old security supported
    • OT-5059J - Direct network unlock in flash mode/New & old security supported
    • OT-5059T - Direct network unlock in flash mode/New & old security supported
    • OT-5059I - Direct network unlock in flash mode/New & old security supported
    • A502DL - Direct network unlock in flash mode/New & old security supported
    • A503DL - Direct network unlock in flash mode/New & old security supported
    • OT-V527 - Direct network unlock in flash mode/New & old security supported
    • OT-V528 - Direct network unlock in flash mode/New & old security supported
    Huawei - Test Point Added per user Request
    • AMN-L21 - boot info/Reset frp & wipe phone via test point.
    • AMN-L22 - boot info/Reset frp & wipe phone via test point.
    • AMN-L23 - boot info/Reset frp & wipe phone via test point.
    • AMN-L29 - boot info/Reset frp & wipe phone via test point.
    • AMN-LX9 - boot info/Reset frp & wipe phone via test point.
    • JAT-L21 - boot info/Reset frp & wipe phone via test point.
    • JAT-L23 - boot info/Reset frp & wipe phone via test point.
    • JAT-L29 - boot info/Reset frp & wipe phone via test point.
    • JAT-L41 - boot info/Reset frp & wipe phone via test point.
    • JAT-LX1 - boot info/Reset frp & wipe phone via test point.
    • JAT-LX3 - boot info/Reset frp & wipe phone via test point.
    • JAT-TL00 - boot info/Reset frp & wipe phone via test point.
    • JAT-TL20 - boot info/Reset frp & wipe phone via test point.
    • MRD-AL00 - boot info/Reset frp & wipe phone via test point.
    • MRD-L11 - boot info/Reset frp & wipe phone via test point.
    • MRD-L22 - boot info/Reset frp & wipe phone via test point.
    • MRD-L23 - boot info/Reset frp & wipe phone via test point.
    • MRD-LX1 - boot info/Reset frp & wipe phone via test point.
    • MRD-LX2 - boot info/Reset frp & wipe phone via test point.
    • MRD-LX3 - boot info/Reset frp & wipe phone via test point.
    • MRD-TL00 - boot info/Reset frp & wipe phone via test point.
    Testpoint images can be opened from settings tab.
    Download Here user Control Panel:
    Index of /downloads
  3. #13
    Jan 2007
    GSM Shield Box LG setup v1.0 initial Release added - [19/12/2019]
    Simple, Yet Powerfull
    Supported Functions
    - Write KDZ / TOT Firmware
    - Read Firmware
    - Format FS without Flash
    - Reset FRP
    - Reset Locks (Old Security)
    - Disable Locks (Old Security)
    - Reset Security
    - Repair IMEI / MEID
    - Extract DZ from KDZ Firmware
    - Extract DZ/TOT to QFIL compatible format
    Added:
    - D295F
    - D325
    - D380
    - D385
    - D392
    - D620
    - D620K
    - D620R
    - D722
    - D722K
    - D725
    - D728
    - D800
    - D856
    - DM02H
    - F490
    - F600K
    - F600L
    - F600S
    - F650K
    - F650L
    - F670K
    - F670L
    - F670S
    - F720S
    - G600L
    - H525TR
    - H736
    - H791
    - H810
    - H811
    - H812
    - H815
    - H815P
    - H815T
    - H815TR
    - H818P
    - H870
    - H900
    - H901
    - H955
    - H960
    - H960AR
    - H960TR
    - H960YK
    - H961N
    - H961S
    - H962
    - H968
    - K350E
    - K350N
    - K350TR
    - K420N
    - K430DS
    - K430DSF
    - K430TV
    - K520DY
    - K530F
    - K535
    - K535D
    - LS450
    - LS675
    - LS676
    - LS775
    - LS777
    - LS991
    - M153
    - M160
    - M250E
    - M250F
    - M250ds
    - M250i
    - M700TV
    - MP260
    - MP260AT
    - MS330
    - MS428
    - MS550
    - P815L
    - US991
    - VS425
    - VS986
    - VS990
    - X210
    - X210DS
    - X210NMW
    - X320K
    - X410BCW
    - X410EOW
    Download support accress software here
    [/B]
  4. #14
    Jan 2007
    GSM Shield Box MTK Setup v1.3 Update is out...
    Added:
    Hisence
    • F16 - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Repair IMEI/Flashing...
    Lava
    • Iris 88 - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Repair IMEI/Flashing...
    Infinix
    • X5516B - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Repair IMEI/Flashing...
    • X5516C - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Repair IMEI/Flashing...
    Alcatel
    • OT-8068 - Read Info/FRP/Remove SimLock/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-A501DL - Read Info/FRP/Remove SimLock/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-5008Y - Read Info/FRP/Remove SimLock/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-5008D - Read Info/FRP/Remove SimLock/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-5008U - Read Info/FRP/Remove SimLock/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-9029G - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-9029W - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    • OT-5008R - Read Info/FRP/Factory reset in flash & meta mode/Backup & Restore nvram in flash & meta mode/Flashing...
    MTK CPU
    • MT6739 - IMEI Repair Meta mode without database.
    • MT6761 - IMEI Repair Meta mode without database.
    • MT6763 - IMEI Repair Meta mode without database.
    • MT6765 - IMEI Repair Meta mode without database.
    • MT6771 - IMEI Repair Meta mode without database.
    Fixed saving firmware for some new helio models.
    Scater saving improved.
    Added fastboot read info function, for phones what support fastboot.
    Official Website:
    https://www.gsmshieldbox.com
    Download from:
    https://drive.google.com/drive/folde...HS?usp=sharing
  5. #15
    Jan 2007
    ​[22-01-20] GSMShield Qualcomm v1.3 - Vivo Secured Phones and more....
    We are happy to announce
    GSMShield
    Qualcomm v1.3
    • - MSM8909
    • - MSM8x10
    • - MSM8x26
    • - MSM8916
    • - MSM8917
    • - MSM8920
    • - MSM8929
    • - MSM8936
    • - MSM8937
    • - MSM8952
    • - MSM8953
    • - MSM8960
    • - MSM8974
    • - MSM8976
    • - MSM8992
    • - MSM8994
    • - MSM8996
    • - MSM8998
    • - SDM7xx
    • - SDM8xx
    Supported Features:
    • - Automatic Selection of programmer
    • - Option to select custom programmer
    • - Automatic Memory Type Detection
    • - Device Identification Function
    • - Read Factory Firmware
    • - Write Factory Firmware
    • - Support Multi Program Firmware Read/Write
    • - Safe Flashing for Security Data Protection
    • - Reset FRP in Flashing Process
    • - Read/Write/Erase Any Partition
    • - Backup/Restore/Erase Security
    • - Reset FRP
    • - Format Userdata
    • - Safe Format Userdata
    • - Supports Both IMEI Repair
    • - Reset Vivo User Lock without Data Loss
    • - Read QCN Data
    • - Write QCN Data
    • - Support for UFS Memory Devices
    • - Xiaomi Mi Account Reset
    • - Xiaomi Mi Account Relock Fix
    • - Xiaomi Factory Reset in sideload
    Added:
    Huawei
    • - Honor 8c (BKK-AL10C)
    • - Y7 Prime (DUB-LX1)
    LeTV
    • - Le 2s
    OnePlus
    • - 3T
    Vestel
    • - Venus E4
    Added Reset Settings for Vivo Secured Phones
    • - Make sure you select correct model
    • - Following Models are Supported:
    • - NEX (PD1805F)
    • - NEX Dual (PD1821F)
    • - V11 Pro (PD1814F)
    • - V9 (PD1730F)
    • - V9 Pro (PD1730CF)
    • - V9 Youth (PD1730BF)
    • - X21 (PD1728F)
    • - Y71 (PD1731BF)
    • - Y71i (PD1731F)
    • - Y91 (PD1818EF)
    • - Z1 Pro (PD1911F)
    • - This method may not work on new patch level.
    Added Bootloader Unlock for Vivo Secured Phones
    • - You can tick Unlock Bootloader while Format
    • - Please note that all data will be lost if you Unlock BL
    Updated Internal Loader Database
    Download From Official Google Drive Mirror Only
    https://drive.google.com/open?id=1rY...EsQE2OuaGjChHS
  6. #16
    Jan 2007
    [29/02/2020] GSM SHIELD Box SPRD Setup v1.2 is out...
    ZTE
    • A5 2019 - Boot Info/Backup NVRAM/Restore NVRAM/Remove FRP/Format Userdata/Reset Userdata and Remove FRP/Write PAC File
    • A7 2019 - Boot Info/Backup NVRAM/Restore NVRAM/Remove FRP/Format Userdata/Reset Userdata and Remove FRP/Write PAC File
    • V10 VITA - Boot Info/Backup NVRAM/Restore NVRAM/Remove FRP/Format Userdata/Reset Userdata and Remove FRP/Write PAC File
    IMO
    • IMO DASK UK (sc7702) - Boot Info/Backup NVRAM/Restore NVRAM/Read Phone password/Read simunlock code/Write Pac File
    Added
    Generic Method to Read phone user Password for Keypad phones in DIAG Mode.
    • - This method is useful when need to keep data so NO DATA LOSS.
    • -- Also some SC6531E phones not allow factory reset from diag mode.
    • -- This method will work only in keypad phones what allow connection in diag mode.
    • --- Method is generic, You do not need to select any model.
    Official Website:
    https://gsmshieldbox.com
    Official Google Drive Download:
    Official Support Downloader and card updater:
    Official Card Updater & Setup Downloader:
  7. #17
    Jan 2007
    Added:
    Hisence
    Lava
    Infinix
    Alcatel
    MTK CPU
    Official Website:
    Download from:
  8. #18
    Jan 2007
    GSMShield
    Qualcomm v1.3
    - MSM8909
    - MSM8x10
    - MSM8x26
    - MSM8916
    - MSM8917
    - MSM8920
    - MSM8929
    - MSM8936
    - MSM8937
    - MSM8952
    - MSM8953
    - MSM8960
    - MSM8974
    - MSM8976
    - MSM8992
    - MSM8994
    - MSM8996
    - MSM8998
    - SDM7xx
    - SDM8xx
    Supported Features:
    - Reset FRP
    - Format Userdata
    - Read QCN Data
    - Write QCN Data
    Added:
    Huawei
    LeTV
    - Le 2s
    OnePlus
    - 3T
    Vestel
    - Venus E4
    - NEX (PD1805F)
    - V11 Pro (PD1814F)
    - V9 (PD1730F)
    - V9 Pro (PD1730CF)
    - X21 (PD1728F)
    - Y71 (PD1731BF)
    - Y71i (PD1731F)
    - Y91 (PD1818EF)
    - Z1 Pro (PD1911F)
  9. #19
    Jan 2007
    ZTE
    IMO
    Added
    Official Website:
  10. #20
    Jan 2007
    GSM Shield MTK Module v1.4 Update is out - 04/03/2020
    Hisence
    F16 - Sim Lock Remove, All Other options already supported
    Huawei
    CRO-L02 - Fixed sim unlock
    CRO-L03 - Fixed sim unlock
    CRO-L22 - Fixed sim unlock
    CRO-L23 - Sim Lock Remove, All Other options already supported.
    ZTE
    A530 - FRP/Factory Reset (Flash & Meta Mode)/Backup & Restore NVRam (flash & Meta Mode)/Repair IMEI/Flashing/Read Info.
    Lenovo
    A5 - FRP/Factory Reset (Flash & Meta Mode)/Backup & Restore NVRam (flash & Meta Mode)/Repair IMEI/Flashing/Read Info.
    TB-7104FDA - FRP/Factory Reset (Flash & Meta Mode)/Backup & Restore NVRam (flash & Meta Mode)/Repair IMEI/Flashing/Read Info.
    Alcatel
    OT-VFD620 - Fixed Unlock in Flash Mode.
    Added:
    Added Generic BootLoader Unlock By Fastboot.
    Added Generic Flashing Unlock by Fastboot.
    -- This function will not work on all phones, some brands have custom way to Unlock Bootloader
    Added Erase FRP and Wipe UserData by Fastboot.
    -- This function will not work on all phones, for this function need to have Unlocked Bootloader.
    Fixed Meta mode for New Helio Models.
    Improved Repair IMEI without database in Meta Mode for New Helio Models.
    -- Not Supported Phones with Read Only and Protected IMEI.
    Official Website:
    Download from:
    RESELLERS WELCOME - WE CAN SHIP FROM CHINA OR DUBAI
