Kết quả 1 tới 10 của 21
    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định CPF-BOX II Updates check here!
    CPF_BOX_II_Setup2008.06.23
    Update details:
    1:support MTK 6228cpu 256M big flash.
    2:support ADI KAD0707 flash.
    3:added 7850 platform.
    4:added si4904 platform.
    5:added MTK password reader platform.
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
    Aug 2006
    Tp.Hồ Chí Minh
    CPF_BOX_II_Setup2008.06.28
    Update details:
    1:fixed some bug.
    2:update MTK platform 2.31
    3:update Spreadturm platform 3.53
    Aug 2006
    Tp.Hồ Chí Minh
    Special Note: Any time you upgrade, You must closed platform.Then u can install new version.
    CPF_BOX_II_Setup2008.07.10
    Update details:
    1:Update Spreadtrum platform V3.53.First support read / write Spreadtrum CPU 6600M/E/D on 1843200 speed in the world.
    2:Fixed some bug with 6600R.
    3:Update infineon platform V2.02.Added some new flash model with Infineon CPU.
    4:Update SI4904 platform V1.20 .Added some new flash model with SI4904 CPU.
    Aug 2006
    Tp.Hồ Chí Minh
    CPF_BOX_II_Setup2008.07.22
    Update details:
    1:update Spreadtrum platform V3.35
    added some new flash models for 6600R
    support 6600M new flash model(K9F5608)
    support 6600R full flash erase/read/write.first in the world
    2:update SI4904 platform V1.21
    added format/unlock function.first in the world
    3:added RSD tool for flash MOTOROLA model
    added V3,V8 pinouts for MOTOROLA model
    4:added MTK Reset UserDate software
    5:Fixed some bug for Spreadtrum
    Aug 2006
    Tp.Hồ Chí Minh
    CPF_BOX_II_Setup2008.07.26
    Update details:
    1:update Spreadtrum platform V3.36
    Direct read lock code with Spreadtrum CPU
    Added 6600R privacy lock read.first in the world
    2:update SI4904 platform V1.22
    Fixed format/unlock function
    3:changed percent display mode
    4:update Infineon 7880 platform V2.1
    Added some new model with 7880CPU
    Aug 2006
    Tp.Hồ Chí Minh
    Note:First install main.exe please ,then install patch.exe
    You must backup flash file before you flash any cpu
    How to use 7880 v2.20 check here
    CPF_BOX_II_Setup2008.08.07main
    CPF_BOX_II_Update_20080807patch
    Update details:
    1:Update Spreadtrum platform V3.57
    Added Spreadtrum change imei.(support 2 imei and you can via change imei unlock 6600M/R NAND flash all lock)
    2:Update Infineon 7880 platform V2.20
    Added some new boot file,auto found flash,support more model
    Added file unlock function.(you can via this avert sim lock with 7880CPU)first in the world.
    2:Added some SAMSUNG model and pinouts.
    C series:
    c120,c200,c210,c230
    D series:
    D100,D410,D420,D480,D500,D520,D600,D820
    E series:
    E100,E310,E330,E340,E350,E410,E530,E560,E600,E610, E620
    E630,E640,E700,E720,E730,E770,E800,E810,E820,E880
    P series:
    P100,P300,P400,P730
    S series:
    S100,S200,S300M,S500
    V series:
    V200
    X series:
    X100,X130,X200,X400,X430,X450,X460,X470,X480,X500
    X600,X620,X640
  1. All Furious Gold News updates post and check here
    By BlachThon in forum FuriouS Team Products
    Bài viết cuối: 23-02-2009, 19:34
  2. JAF Plus updates, check here!!!!
    By saigonmobile in forum JAF_ Plus
    Bài viết cuối: 20-02-2009, 21:44
  3. All Cruiser software News updates post and check here
    By BlachThon in forum Cruiser Box
    Bài viết cuối: 29-01-2009, 03:16
  4. Trả lời: 2
    Bài viết cuối: 21-06-2008, 22:17
  5. *** VE-King Updates Section ***Check Here Only !!!
    By saigonmobile in forum VE-KING
    Bài viết cuối: 21-06-2008, 22:11
