    V.I.P tôn tẩn's Avatar
    A HÙNG VÙNG 7 NÚI
    Mặc định ae xem log 6030 giùm e
    ace xem mình chạy pm và unlock báo như thế này là ok rùi hay có lỏi j k ace thanks all sao máy mình vẩn k có sóng ae xem giùm
    JAF version 1.98.63
    Detected PKEY: 9001AFA3
    Card life counter: 46.94%
    USB Cable Driver version: 7.0.2.0
    Setting local mode...
    Phone Type: RH-19
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    PPM Flash file: D:\FILE DCT4-DCT5\3120-3100 RH-19\rh19__06.31t
    Reading IMEI...
    Reading IMEI data...
    Building RPL backup file...
    C:\Program Files\ODEON\JAF\ProgData\355037009629521_imei_back up_201713.rpl
    Done!
    Backup imei OK!
    PPM: D:\FILE DCT4-DCT5\3120-3100 RH-19\rh19__06.31t
    Booting phone...
    MCU ID: 0x1120
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    FLASH ID0: 7E270100 <=> Flash ID not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    FLASH ID1: 01000000 <=> Flash -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
    Flash ID is 0x7E270100
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 1d
    Loader is ready...
    MSID: 84396007FA4D48C1AA467F7985
    MSID decoded: D474BAE900C1C0E3A8000000
    FAID: 17167736828034E81C9831B5
    Operation took 0 minutes 8 seconds...
    Erasing PPM...
    Found 1 interval(s) to erase
    Erasing area: 01550000 - 0167FFFF...
    Operation took 0 minutes 9 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 6 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 0 minutes 25 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-19, Software version: 06.31
    IMEI: 355037009629521
    Product Code: 0513169
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: 2
    SW version: 06.31
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 223
    DTDD HỮU NHÂN D/C NHÀ BÀNG-TỊNH BIÊN-AN GIANG
    DT : 09 48 48 73 48 - 09 46 46 1984 - 01 99 33 29 298 YH - i_love_you_welcome_to_huu_nhan
    Thành viên kỳ cựu setot_thoi's Avatar
    Aug 2007
    Sóc Trăng
    log ok không sóng xem lại fie RH-19 . . . . Thân
    MẩnMobile .Y/H : Jimmyphong10
    Thành viên kỳ cựu tungculao's Avatar
    Feb 2009
    TCL.VN
    trời nap rh19 ..có nguồn mà thiếu sóng....lộn chổ nào vậy coi lai đi.6030 hay 3120
    A HÙNG VÙNG 7 NÚI
    ae cho mình hỏi với mình chạy file pm k là cái file nào vậy ace mình lấy file pm trong 3 file đó đúng k ace hây file pm khác nửa thanks ace nhìu
    A HÙNG VÙNG 7 NÚI
    ý trời lộn 3120 ace ui
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    không có sóng thì từng trường hợp chứ. Anh chạy lại đúng FW, write pm, unlock, factory chp đúng đi. Sau đó kiểm tra mất sóng thu hay mất sóng phát, dựa vào mất đường nào thì làm đường đó theo sơ đồ
  1. ae hướng dẩn giùm e cách repait boot con ss s5230 giùm e với
    By truong25071990 in forum Phần mềm Samsung
    Bài viết cuối: 14-01-2012, 14:57
  2. cần anh em chỉ giùm updat model giùm
    By tranquocthangts in forum J.A.F
    Bài viết cuối: 07-06-2011, 13:06
  3. 6030 dèn bàn fím không lên giúp giùm
    By prettyghost20 in forum DCT4 - WD2
    Bài viết cuối: 12-05-2011, 14:07
  4. cứu giùm cây 6030
    By dentutrieuchau in forum DCT4 - WD2
    Bài viết cuối: 11-03-2009, 21:56
  5. Trả lời: 7
    Bài viết cuối: 09-05-2007, 09:47
