các bác xem dum em cái log
MCU ID: 0x2031
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 7.02
10-12-07
RH-93
(c) NMP
HW version: 0526
PCI version:
UEM version: 1328
UPP version: 8241
RFIC version: 0500
DSP version: P05w06.v34
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 7.02
10-12-07
RH-93
(c) NMP
MD
ADSP SW version: V 7.02\n10-12-07\nRH-93\n(c) NMP\nmd
Production serial number: IFE116664
Product code: 0536461
Module code: 0203169
Basic production code: 0536354
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: n?????????????????????????????????????????????????
Default SN type: n?????????????????????????????????????????????????
IMEI plain: 350604400553132
IMEI spare to net: 3A 05 06 44 00 55 13 03
IMEI SV to net: 33 05 06 44 00 55 13 43 F5
Master Code: 0473035426
Phone type: RH-93, Software version: 7.02, Language Pack: MD
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-93.ini
Setting local mode...
Reading product code...
Product Code: 0536461
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: \Products\RH-93\
No ini files found...
Done!
thacks
