mấy em pị vô nước.đã làm có nguồn nhưng khi kẹp nguồn gọi thi máy báo hết pin rùi tắt nguồn.em đã chạy Getting MCU ID
MCU ID: 0x2142
FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.23
26-10-07
RM-166
(c) Nokia.
HW version: 4051
PCI version:
UEM version: 416
UPP version: 8514
RFIC version: 0205
DSP version: P05w06.v40
LCD version: SUEZ
PPM version: V 04.23
26-10-07
RM-166
(c) Nokia.
V
Production serial number: DGN366197
Product code: 0534571
Module code: 0202972
Basic production code: 0531001
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: h????????????????????????????????????????????????
Default SN type: h????????????????????????????????????????????????
IMEI plain: 351868012888108
IMEI spare to net: 3A 15 68 08 21 88 18 00
IMEI SV to net: 33 15 68 08 21 88 18 00 F9
Master Code: 6727437774
Phone type: RM-166, Software version: 04.23, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-166.ini
Setting local mode...
Reading product code...
Product Code: 0534571
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-166\
Checking path: \Products\RM-166\
No ini files found...
Done!
Setting test mode...
Setting FULL FACTORY...
Operation took 0 minutes 8 seconds...
Done!
Resetting USER DATA...
Operation took 0 minutes 0 seconds...
Done!
Resetting LEAVE FACTORY...
Done!
Resetting SERVICE CENTER...
Done!
Resetting UPGRADE SOFTWARE...
Done!
Resetting PRODUCTION TUNE...
Done!lại va máy báo nhung thế này .mong moi người giúp.thanks
Email: kimluanmobile@gmail.com
