tình trạng máy rơi nước, em đã lam lại upp+nguôn+flat mà không lên nguôn. em flat băng mx key log báo lỗi như sau ; Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00DAE144A3BDA66
ASIC type: 11
UEM Imei: 35520203582307
Flash Imei: 35520203582307
RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35520203582307_BA CK.rpl"
Processing MCU file: rh112_003.000
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00DAE144:2984DA60
Area [01000000-0100FFFF] erased in 1.172 s
Area [01010000-013AFFFF] erased in 1 min 4.718 s
Area [013B0000-013EFFFF] erased in 4.484 s
Area [017C0000-017EFFFF] erased in 0.203 s
Area [01FC0000-01FEFFFF] erased in 0.157 s
Flash programming ...
Error while programming [14] at 0x01000000, Result: 0872
flashing terminated !
RX Buffer: 0872
mong ae nhiệt tình giúp đỡ. thanks all
