Kết quả 1 tới 8 của 8
    Thành viên chính thức tienthe083's Avatar
    Mar 2011
    Mặc định 6600 lên nokia tắt máy cần anh em giúp
    đây là lock em chạy =mxkey lính mới vào nghề nên còn yếu. mong anh em giúp đỡ thank tất cả.!!!!!!
    Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
    ASIC ID: 0x0082 [UPP_WD2 ver: 2.0 or 2.01 or 2.1]
    SecondaryBoot: w2_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x1058
    Supported Ids: 0082
    FlashID0: 0001 267E [AMD Am29N643,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF
    FlashID1: 0001 267E [AMD Am29N643,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF
    FlashID2: 0001 267E [AMD Am29N643,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
    FlashID3: 0001 267E [AMD Am29N643,64 Mbits] page size: 64 K type: NOR area: 06000000-067FFFFF
    ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
    Algorithm: w2_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x71A8
    Supported Ids: 0082
    UEM ID: 00C768D8:2984DA7E
    ASIC type: 5
    UEM Imei: 35154600163975
    Flash Imei: 35154600163975
    RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35154600163975_BA CK.rpl"
    Processing MCU file: NHL105530.35
    [WD2 BT2,WD2 ALGORITHM] size: 1.35 MB
    Supported Ids: 0082, 1081
    Supported Ids: 0082
    Supported Ids: 0082
    Area [00000000-0000FFFF] erased in 0.563 s
    Area [02000000-0214FFFF] erased in 11.625 s
    Flash programming ...
    Programming completed in 22.453 s
    File Processed in 52.297 s
    Processing PPM file: NHL105530.C1
    [WD2 BT2,WD2 ALGORITHM,WD2 CBUS BT] size: 22.21 MB
    Supported Ids: 0082
    Supported Ids: 0082
    Algorithm: w2_cbusb.fia [WD2 CBUS BT] version: 4.76.0 revision: 0.7 size: 0x25
    Supported Ids: 0082
    Area [00000000-0000FFFF] erased in 0.562 s
    Area [00010000-007FFFFF] erased in 1 min 5.469 s
    Area [04000000-046FFFFF] erased in 56.781 s
    Area [06000000-066FFFFF] erased in 56.359 s
    Area [047C0000-047EFFFF] erased in 1.781 s
    BT MCM image (0x21): 0002DD94
    Programming BT image ...
    BT image written.
    Programming completed in 6 min 49.625 s
    File Processed in 10 min 11.140 s
    Total time for flashing process(boot+erase+write) was 11 min 3.437 s
    Phone Type: NHL-10
    SW Version: V RD_2004_wk45 03-11-04 NHL-10 (c) NMP.
    Imei plain: 35154600163975-3
    Product Code: 0511970
    Cellular System: GSM
    ASIC ID: 0x0082, type: 5
    Language Pack:
    - not available.
    Failed to read SP data
    Thành viên tích cực trantukiet1008's Avatar
    Dec 2009
    Write cho có cái pm rồi unclok done
    Ai đem con cá đến cho con mèo
  3. ( trantukiet1008 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tienthe083 (20-04-2011)
    Thành viên tích cực vantungnguyen's Avatar
    Nov 2010
    Trích Được post bởi trantukiet1008 Xem bài viết
    làm như anh này xong ấn nút thanks là xong hết nè. không xong thì ấn vài lần nút không thanks nữa nhé. hjhj, làm nhanh rồi đong lúa kìa
    Cuộc đời vẫn là cuộc đời........ YM: tung_tn1
  5. ( vantungnguyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Mar 2011
    may anh cho em cái (6600 pm full ) lun đi..làm thì làm cho chót hjhjhhj..!!! thank rất là nhìu
  7. #5
    Dec 2009
  8. #6
    Mar 2011
    em tải về rùi nhưng sao ấn vào write nó ko chạy.anh hướng dẫn cho em tí nửa nhék .cảm ơn anh nhìu(lính mới mấy anh đừng chém em nhak jhjhjhjh.)
  9. #7
    Thành viên kỳ cựu duyquang_mobile's Avatar
    Oct 2009
    qua yahoo mình làm cho
    SỐNG TRÊN ĐỜI PHẢI CÓ CHỮ TÂM . DTDD :0922972486
    MUỐN THÀNH CÔNG PHẢI CÓ CHỮ NHẪN.... yahoo nguyenquang_201086
  10. ( duyquang_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #8
    Mar 2011
    em cảm ơn anh duyquang_mobile nhìu nhek..!!!!!thank thank ........thank..thank.....!!!!!!!!
  1. Cần giúp Cáp Nokia 6600
    By Minh Long in forum DCT4 - WD2
    Bài viết cuối: 07-07-2014, 12:14
  2. NOKIA 6600 cần giúp.
    By khanmobiphone in forum DCT4 - WD2
    Bài viết cuối: 08-05-2013, 17:31
  3. Trả lời: 2
    Bài viết cuối: 23-12-2009, 08:54
