em mới nhận cay 2320c-2b ,log check info
MCU ID: 0x3168
FLASH ID0: 89810089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
First 16 bytes: AD 7E B6 1B 23 10 03 40 C6 05 E4 01 20 A2 00 00
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 11.10
19-05-10
RM-515
(c) Nokia
HW version: 1501
PCI version:
UEM version: 4386
UPP version: 12648
RFIC version: 0500
DSP version: unnithan23061610
LCD version: SUEZ
PPM version: V 11.10
19-05-10
RM-515
(c) Nokia
NCR
Content Pack version: Content: ncr_attus_19May10
V 11.10
19-05-10
RM-515
(c) Nokia
Production serial number: HGD474956
Product code: 059D431
Module code: 0204047
Basic production code: 0571673
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 012185001529093
IMEI spare to net: 0A 21 81 05 10 25 09 09
IMEI SV to net: 03 21 81 05 10 25 09 59 F8
Master Code: 3063735604
Phone type: RM-515, Software version: 11.10, Language Pack: NCR
User code: 12345
Block 1:
Lock 1: CLOSED -> Lock Data: 310150
Block 2:
Lock 1: CLOSED -> Lock Data: 310170
Block 3:
Lock 1: CLOSED -> Lock Data: 311180
Block 4:
Lock 1: CLOSED -> Lock Data: 310410
Block 5:
Lock 1: CLOSED -> Lock Data: 310980
Block 6:
Lock 1: CLOSED -> Lock Data: 00101F
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-515.ini
Setting local mode...
Reading product code...
Product Code: 059D431
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-515\
Checking path: \Products\RM-515\
No ini files found...
Done!
em có nbox chạy qua giao diện JAF và có thể chạy HWK 2.1.1.0
nay cần anh em hướng dẫn em
