u+MXKEY Serial: [FT SCR2000 0] - C080777B Using device: UFS_USB V2.8 (c) SarasSoft 2007. Driver: UFS2XX, ver: 3.6.0.0, NTMP ver: 2.6.0.0 Module ver: 1.0.0.16662(04-05-2011), Library ver: 1.0.0.9921(04-05-2011) ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00811432A3BDA66 ASIC type: 11 UEM Imei: 35152804812872 Flash Imei: 35152804812872 RPL saved to "C:\mobileEx\3.4\data\backup\RPL\35152804812872_BA CK.rpl" Processing MCU file: rh105_05.060 [DCT4,DCT4 ALGORITHM] size: 2.27 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00811432:2984DA60 Area [01000000-0100FFFF] erased in 0.422 s Area [01010000-013AFFFF] erased in 21.047 s Area [013B0000-013EFFFF] erased in 1.485 s Area [017C0000-017EFFFF] erased in 0.125 s Area [01FC0000-01FEFFFF] erased in 0.125 s Flash programming ... Programming completed in 17.453 s File Processed in 49.718 s Processing CNT file: rh1050_nai5.06mr [DCT4,DCT4 ALGORITHM] size: 139.48 KB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00811432:2984DA60 Area [01380000-013AFFFF] erased in 1.156 s Flash programming ... Programming completed in 1.109 s Content extract fail, continue anyway ... File Processed in 3 min 39.454 s Processing PPM file: rh105_05.06mr [DCT4,DCT4 ALGORITHM] size: 1.19 MB Supported Ids: 2292 ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2606 [Samsung K8S3215ETF,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 00811432:2984DA60 Area [01240000-0124FFFF] erased in 0.359 s Area [01250000-0137FFFF] erased in 6.875 s Flash programming ... Programming completed in 9.172 s File Processed in 41.000 s Total time for flashing process(boot+erase+write) was 5 min 10.187 s Phone not responding ! lae nào giúp mình với 1208 mất nguồn,thay u+flash chạy ct báo lổi.ae xem log đoán bệnh dùm bệnh gì mà làm hoài chẳng được cảm ơn nhiều!
