AE xem cho cái loc 1110i thay CPU ,FLAT rùi chay phần mềm báo như vậy kg viết IMEL và IN FO + đồng bộ đc
MCU ID: 0x2201
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\1110i\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
Flash ID is 0x28882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_st_i.fia
Loader size is 0x4B28; Loader chk: c9
Loader is ready...
MSID: 8449FB3B59DB6F53A79B5BA65A
MSID decoded: 3E4EBAE9000232E6AA000000
FAID: 9E301EF138902E0E5B08BF9E
Operation took 0 minutes 10 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 1 minutes 6 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 13 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\1110i\rh93_07.02md
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 26 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 57 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-93, Software version: 7.02
IMEI: ???????????????
Product Code:
Resetting PPC...
Done!
chạy thử HWK và JAF chạy các Ver khác nhau kg dc AE cho ý kiến thanks nhìu
