Kết quả 1 tới 9 của 9
    Vi phạm nội quy lamvtmobile's Avatar
    Sep 2008
    Mặc định 2610b không flash được pm
    ae giúp máy 2610b đả unlock xong mình nhận khách nạp tiếng việt nhưng mcu và cnt thì được nhưng không nạp được pm , đây là log của nó.
    MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 3] - C0859271
    Using device: HTI BOX, FW ver: 00.17
    Driver: usbuhci:usbhub:usbccgp:WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.17841(12-07-2011), Library ver: 1.0.0.11875(12-07-2011)
    ASIC ID: 0x3168 [UPP_8M ver: 6.4]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
    FlashID0: 0001 2C7E [AMD S29NS128N,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00C76F58:3B8ADA60
    ASIC type: 11
    UEM Imei: 01168400138434
    Flash Imei: 01168400138434
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\01168400138434_BA CK.rpl"
    Processing MCU file: rh86_87__05.65.mcusw
    [DCT4,DCT4 ALGORITHM] size: 8.62 MB
    Supported Ids: 3040
    UEM ID: 00C76F58:1821DA60
    Area [01000000-0101FFFF] erased in 0.718 s
    Area [01020000-018DFFFF] erased in 50.032 s
    Area [01EE0000-01FDFFFF] erased in 6.235 s
    Flash programming ...
    Programming completed in 2 min 0.750 s
    File Processed in 3 min 8.797 s
    Processing CNT file: rh86_87__05.65.image_v
    [DCT4,DCT4 ALGORITHM] page size: 64 K size: 1.19 MB
    Supported Ids: 3040
    UEM ID: 00C76F58:C5A4DA78
    Area [01B80000-01EDFFFF] erased in 19.422 s
    Converting UCP blocks to 128 K.
    Programming completed in 15.578 s
    Content extract fail, continue anyway ...
    File Processed in 1 min 13.031 s
    Processing PPM file: rh86_87__05.65.ppm_v
    [DCT4,DCT4 ALGORITHM] size: 2.44 MB
    Supported Ids: 3040
    Boot error: CC CC CC 00
    - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
    - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
    - On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
    flashing terminated !
    Task failed at (0800002A)!!!
    Last RX buffer: 02 00
    ae xem hướng dẩn giùm mình mới tập chạy phần mềm nên không rành lắm. Thanks ae trước.
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    Last RX buffer: 02
    check lại cáp khác nha bạn hiền.cần thì sóa full đi rôì nạp lại
    Sep 2008
    Trích Được post bởi tlpmobile_tk Xem bài viết
    đổi cáp đa năng cũng vậy bạn ơi....
    Sep 2008
    bạn có thể chỉ cho mình cách xóa full không thanks nhiều.
    Thành viên mới ta la ta's Avatar
    Aug 2011
    ban ko can thay j
    ban thu lay lai pm cu cua no xem the nao
    neu ko dc thi ban vao
    pm viet xuanhanh.com
    Thành viên tích cực gamoi.gsm's Avatar
    Jul 2011
    cho vào cáp đa năng chỉnh điện trở 3k3 đảm bảo ok.
    yah:Gamoi_gsm@yahoo.com.vn
    Sep 2008
    không biết sao mình không write pm được mình chọn pm chọn write pm khoản 1 phút là nó văng ra không write được..
    Jul 2011
    thay con trở đôi r2205 xem thế nào a
    Sep 2008
    Uh để mình thư xem sao..
  1. 2610b mở mạng xóa flash ko dc
    By Toan_MoBiLe_TN in forum DCT4 - WD2
    Bài viết cuối: 26-10-2011, 21:09
  2. JAF 1.98.64 sờ 2610b v7.04a?
    By cu_hung in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 11-10-2009, 16:01
  3. help!!!!! van de ve 2610b
    By binhthaile in forum DCT4 - WD2
    Bài viết cuối: 15-07-2008, 12:50
  4. Nokia Flash File 2610b
    By DNA in forum NOKIA
    Bài viết cuối: 08-11-2007, 10:52
  5. Cần flash file của 2610b rh87!
    By hieuhanh11 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 02-10-2007, 14:27
