e có cây 1600 rơi nước chết nguồn làm lên nguôn nhưng bị contact service nhờ các bác xem hô e cái log
MXKEY Serial: C0843E1B
Library version: 1.0.0.9627(20-04-2011), 1.0.0.16202(20-04-2011)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
UEM ID: 00D027F4:2984DA60
ASIC type: 2
UEM Imei: 35932302596076
Flash Imei: 35932302596076
MasterCode: 6635300332
RPL saved to "C:\mobileEx\3.4\data\backup\35932302596076_BACK.r pl"
Phone Type: RH-64
SW Version: V 7.02 10-12-07 RH-64 (c) NMP
Imei plain: 35932302596076-9
Product Code: 0525094
Cellular System: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: MD
Language Pack:
English,Filipino,Vietnamase
Imei net: 35932302596076
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
: 0934.80.22.28 . Gmail :
