anh ơi ime trên xường ko phải của máy,em restor ime lai thì đươc mấy số này,nhưng có 14 số ak anh,để em đưa log lên ae coi rồi giúp em.MXKEY Serial: [MxKey HTI FLASHER INTERFACE 1] - C0855BFC
Using device: HTI BOX, FW ver: 00.07
Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00C20320A3BDA66
ASIC type: 11
UEM Imei: 35196103046261
Flash Imei: 35196103046261
MasterCode: 2375115360
RPL saved to "C:\mobileEx\3.5\data\backup\35196103046261_BACK.r pl"
Phone type: RH-112
SW version: V 03.10 21-01-09 RH-112 (c) NMP
Imei plain: ??????????????-?
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MR
Language Pack:
- not available.
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!thay uem xong restoer ime lai xong check thì lên log này,ae giúp em.no có 14 số ak.
A3BDA66
