1280 rớt nước mất nguồn. đã làm lại cpu, flash thì báo lổi thế này, nhờ ace giúp, thanks all
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
Using device: HTI BOX, FW ver: 00.24
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_006.200
Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 50.406 s
Erasing area 0x00C60000-0x00E4D5BE ...OK
Programming completed in 48.265 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.188 s
Error reading checksum!
Processing file: rm647_006.20ia
Downloading item CUST:hw_b2_rm647_006.20ia.fls, num block: 1, size: 1.28 MB
Erasing area 0x00210000-0x00355A3E ...OK
Programming completed in 32.812 s
Checksum mismatch: Phone calculated 0x0036, software calculated 0xCCA3
Processing file: rm6470_nai06.20ia
Downloading item CUST:hw_b2_rm6470_nai06.20ia.fls, num block: 1, size: 348.33 KB
Erasing area 0x00EB0000-0x00F0643E ...OK
Programming completed in 8.906 s
Checksum mismatch: Phone calculated 0x00F1, software calculated 0x7F11
Total time for flashing process(boot+erase+write) was 3 min 49.515 s
