Kết quả 1 tới 10 của 12
    Thành viên tích cực PHÁT TÀI's Avatar
    Mặc định làm ơn xem giúp em xem dùm log 1280
    1280 rớt nước mất nguồn. đã làm lại cpu, flash thì báo lổi thế này, nhờ ace giúp, thanks all
    MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
    Using device: HTI BOX, FW ver: 00.24
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbps
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Processing file: rm647_006.200
    Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 50.406 s
    Erasing area 0x00C60000-0x00E4D5BE ...OK
    Programming completed in 48.265 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.188 s
    Error reading checksum!
    Processing file: rm647_006.20ia
    Downloading item CUST:hw_b2_rm647_006.20ia.fls, num block: 1, size: 1.28 MB
    Erasing area 0x00210000-0x00355A3E ...OK
    Programming completed in 32.812 s
    Checksum mismatch: Phone calculated 0x0036, software calculated 0xCCA3
    Processing file: rm6470_nai06.20ia
    Downloading item CUST:hw_b2_rm6470_nai06.20ia.fls, num block: 1, size: 348.33 KB
    Erasing area 0x00EB0000-0x00F0643E ...OK
    Programming completed in 8.906 s
    Checksum mismatch: Phone calculated 0x00F1, software calculated 0x7F11
    Total time for flashing process(boot+erase+write) was 3 min 49.515 s
    Thành viên kỳ cựu nhathuy_mobile2009's Avatar
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    thử cáp khác xem anh ,không được nữa thì chỉ còn cách thay cặp thôi
    Thành viên mới tuanlinhmobile88's Avatar
    Nov 2011
    1280 lây đâu ra cặp thế. có 1cpu 1pa . bạn nhầm ah
    Thành viên kỳ cựu phone_lucky's Avatar
    bình phước
    Trích Được post bởi tuanlinhmobile88 Xem bài viết
    cặp của nó là Cpu và Flash đó bạn, bạn nhìn thế nào mà nói là chỉ có CPU và PA
    May 2011
    Hà Nội City
    Con nào mà chẳng có cặp??
    đến máy TQ còn có nữa là máy nokia vẫn là 1 cặp từ bao đời nay
    đã nghe thấy con nào mà plash tích hợp với U đâu nhỉ?
    Còn máy của bạn đầu tiên nên thay cáp khác và mang qua box khác xem thế nào đã nhé
    đá cho con upp 1 phát đi bạn 1280 rớt nc hay bi vậy
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    Mình nghĩ lỗi do UPP chân chưa chuẩn Bạn làm lại chân thật chuẩn đóng lạo xong flash coi thế nào
    Thành viên chính thức anhtuan050478's Avatar
    May 2007
    Còn máy của bạn đầu tiên nên thay cáp khác và mang qua box khác xem thế nào đã nhé[/QUOTE]
    bó tay toàn tập, 1280 ic nó tích hợp flash + nguồn + trung tầng + cpu đó bạn
    bình phước
    [QUOTE=bó tay toàn tập, 1280 ic nó tích hợp flash + nguồn + trung tầng + cpu đó bạn[/QUOTE]
    Pro nào đây nữa, mod đi ngang đóng topit tránh lại tranh cãi.
    May 2007
    sr nó không tích hợp flash
  1. các bác xem dùm log 1280
    By thuanwhisky90 in forum DCT4 - WD2
    Bài viết cuối: 04-03-2013, 17:33
  2. ae xem dùm cây 1280
    By NGỌC HÒA_GSM in forum Sửa chữa phần cứng
    Bài viết cuối: 29-10-2012, 10:58
  3. nhờ ae giúp dùm cây 1280
    By NGỌC HÒA_GSM in forum DCT4 - WD2
    Bài viết cuối: 02-10-2012, 14:59
  4. ae xem dùm 1280
    Bài viết cuối: 04-09-2012, 09:40
  5. xin giúp dùm máy 1280
    By HOAINAM GSM in forum DCT4 - WD2
    Bài viết cuối: 20-05-2012, 08:49
