ĐƠ_NGUYỄN (28-11-2011)
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
Using device: HTI BOX, FW ver: 00.24
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 88C0 [ST M58MWR064FU,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...ASIC type: 11
UEM Imei: Empty
Flash Imei: 01188400431238
MasterCode: 3264205663
RPL saved to "C:\mobileEx\3.5\data\backup\_BACK.rpl"
Phone type: RH-121
SW version: V 03.10 02-11-09 RH-121 (c) Nokia
Imei plain: 01188400431238-9
Product code: 0584525
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: UB
Language Pack:
- not available.
Imei net: 01188400431238
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
pro cho em hỏi thêm là có cần phải Thay CPU ID 2292
nếu thay tụ lọc và flash lại rh-122 thì sóng ok kg pro, thanks
