nó chung 1202-1280 đó bạn
xem cáp nào giồng cái này thì múc nhe bạn
Up.Anhso.net - Tiện ích up ảnh miễn phí, không cần đăng ký!
anh em có sơ đồ cau bsi con này chỉ mình với
Getting MCU ID
Incorect MCUID!
Causes:
1. Cable is not good -> check for 68k resistor b/w bsi-gnd in connector and 3.3k resistor in serial with bsi line
MCU ID: 0xFFFF
Can't find boot file...
Failed! Aborting!
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 06.20
01-12-10
RH-125
(c) Nokia
HW version: 3007
PCI version:
UEM version: 1328
UPP version: 8850
LCD version: UNKWN: IDs:
00:00:00
PPM version: V 06.20
01-12-10
RH-125
(c) Nokia
MR
ADSP SW version: V 06.20\n01-12-10\nRH-125\n(c) NMP\nmr
Production serial number: 118C409AH
Product code: 0590487
Module code: 0204373
Basic production code: 059F8R0
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 357000043944197
IMEI spare to net: 3A 75 00 00 34 49 14 09
IMEI SV to net: 33 75 00 00 34 49 14 59 F6
Master Code: 5451125205
Phone type: RH-125, Software version: 06.20, Language Pack: MR
User code: ÿ#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-125.ini
Setting local mode...
Reading product code...
Product Code: 0590487
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-125\
Checking path: \Products\RH-125\
No ini files found...
Done!
anh em cho ý kiến nha,cảm ơn
anh em giúp em với ,em đang chờ ý kiến
