log jap:
Getting MCU ID
MCU ID: 0x2293
FLASH ID0: 88280020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD 7E B6 1A 23 10 03 40 C6 05 E4 01 20 A2 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.03
29-06-09
RH-112
(c) Nokia
HW version:
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: INLX:SERIv91
NT7542
PPM version: V 04.03
29-06-09
RH-112
(c) Nokia
MR
ADSP SW version: V 04.03\n29-06-09\nRH-112\n(c) NMP\nmr
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354189035613028
IMEI spare to net: 3A 45 81 09 53 16 03 02
IMEI SV to net: 33 45 81 09 53 16 03 12 F9
Master Code: 5352726607
Failed reading simlock data...
Phone type: RH-112, Software version: 04.03, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Done!
Unlocking...
IMEI: 354189035613028
ASIC: b
SW version: 04.03
Unlock not supported!
Failed! Aborting!
