Kết quả 1 tới 10 của 10
    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định xin xem giúp log 1280
    1280 máy bị rớt đất sóng chập chờn , em flash thì lo như thế này, nhờ ae giúp,
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Processing file: rm647_006.510
    Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 37.750 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 36.219 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.250 s
    Error reading checksum!
    Processing file: rm647_006.51mr
    Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 18.156 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0x1507
    Processing file: rm6470_nai06.51mr
    Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 5.000 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xA1D0
    Total time for flashing process(boot+erase+write) was 2 min 56.157 s
    Dec 2011
    còn đây la log check của em nó ,
    Dec 2011
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    máy rớt đất thì trước tiên kiểm tra lại PA tới upp lun ( gia cố lại , ) dễ bị hở chân con này mang sang nboxx flash chuẩn hơn bạn . rồi writer file pm (bỏ 132)
    yahoo: viethuy_mobi
    Thành viên tích cực gsmmientrung's Avatar
    Jan 2012
    máy rớt đất thì kiểm tra kỷ xem có mất con trụ trở nào ko.. rồi khò lắc nhẹ CPU và LASH lại xem vẩn ko dc thì làm chân lại CPU va Lash lại luôn anh chúc thành công
    Thành viên chính thức ngocthangmobile_tn's Avatar
    Jul 2011
    100 con máy bị rơi hỏng phần cứng,hiếm con nào bị phần mềm lắm!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
    Jul 2011
    mang sang atf đi bạn 1280 khó dùng thằng ngon,bổ,dẻ phang được lắm!!!!!!!!!!!!!!!!!!!!!!!viết pm unkock là ok nhưng tớ nghĩ sóng vẫn bị nt thui!!!!pải làm phần cứng nha!
    TP Hồ Chí Minh
    Trích Được post bởi ngocthangmobile_tn Xem bài viết
    1280 mà đòi unlock hả bạn? em này thì gia cố lại những em khả nghi như CPU. khả năng em này là cao.
    Thành viên kỳ cựu hà_vũng tàu's Avatar
    unlock xong đem làm mô hình luôn !!!!!!!!!!!!!!
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    dò mạng xem mất thu hay mất phát nhưng thường thì dòng này hay bị lỗi ở cpu vì cpu tích hợp cả trung tầng
  1. Trả lời: 9
    Bài viết cuối: 08-10-2014, 21:25
  2. giúp em với 1280 dao đông lắc lư
    By 17121985 in forum DCT4 - WD2
    Trả lời: 18
    Bài viết cuối: 28-09-2012, 21:12
  3. xin giúp 1280
    By TRUONGMOBILE-123 in forum DCT4 - WD2
    Bài viết cuối: 28-09-2012, 12:47
  4. xin giúp 1280
    Trả lời: 20
    Bài viết cuối: 20-09-2012, 08:55
  5. 1280 xin giúp
    By quangdung-886 in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 16-07-2012, 11:57
