1280 máy bị rớt đất sóng chập chờn , em flash thì lo như thế này, nhờ ae giúp,
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
Using device: HTI, FW ver: 00.50, SN: 0000B3E9
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_006.510
Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 37.750 s
Erasing area 0x00C60000-0x00E5933E ...OK
Programming completed in 36.219 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.250 s
Error reading checksum!
Processing file: rm647_006.51mr
Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003288BE ...OK
Programming completed in 18.156 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0x1507
Processing file: rm6470_nai06.51mr
Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
Erasing area 0x00EB0000-0x00EFBA3E ...OK
Programming completed in 5.000 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0xA1D0
Total time for flashing process(boot+erase+write) was 2 min 56.157 s
