tình hình máy của tiệm cầm đồ . để 1 tháng máy mất nguồn . máy zin chưa sửa chửa
Backup saved to C:\mobileEx\3.5\data\backup\XGOLD_RM-647_B5953613798F6EE5_IMEI.back
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085CF97
Using device: HTI, FW ver: 00.50, SN: 00015E67
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_003.600
Downloading item CODE:hw_b2_rm647_r03.600.fls, num block: 3, size: 3.97 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 39.890 s
Erasing area 0x00C60000-0x00E4883E ...OK
Programming completed in 36.672 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.156 s
Error reading checksum!
Processing file: rm647_003.60mr
Downloading item CUST:hw_b2_rm647_003.60mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003286FE ...OK
Programming completed in 18.828 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0x5870
Processing file: rm6470_nai03.60mr
Downloading item CUST:hw_b2_rm6470_nai03.60mr.fls, num block: 1, size: 308.70 KB
Erasing area 0x00EB0000-0x00EFC5BE ...OK
Programming completed in 5.140 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0x86E6
Total time for flashing process(boot+erase+write) was 3 min 1.281 s
Phone type: RM-647
SW version: V 03.60 01-04-10 RM-647 (c) Nokia
Imei plain: 35790804128801-3
Product code: 0593211
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MR
Language Pack:
English,Hindi,Bengali
Imei net: 35790804128801
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
