thay thử cái màn hình xem sao bạn
				ImageFile:C:\Documents and Settings\Admin\Desktop\1600_RH_64_Ver_06.93\rh64_0 6.930
PhoneType : DCT4
Algorithm : DCT4 ALGORITHM
Supported Hardwares :
> 0120
> 0121
> 1021
> 1120
> 1130
> 1131
> 1201
> 2140
> 2142
> 2201
> 2031
> 2030
> 2032
> 2033
Secondary Sending Speed : 100000Hz
Algorithm Sending Speed : 6500000Hz
Program Sending Speed : 6500000Hz
Message Reading Speed : 51000Hz
Number of Blocks : 119
Entry Point: 0x0101
Is128k: True
Boot Check, Please wait...
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
Boot File: C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia
DataLen : 000009D8
Secondary Loader Sent...
Boot OK!
MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
DCT4 Mess 9F MUL3 Mess 9F
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0001 - SPANSION
DevId0 : 2A7E - Type not in database
ExtId0 : 0024
RevId0 : 0111
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ManuId1 : 0000 - Flash
DevId1 : 0001 - not used
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
CheckSum : E0
ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
SearchForBootstrap_DCT4 : No Error
Algo Match File : C:\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_amd.fia
ALGO SENT..
Perform AUTHENTICATION..
MSID: 841F3EEA0181E0C56975F5252C
DecodedMSID: 843E4EBAE900D481A7A9000000
EncodedFAID: C5A316D39E7EE316EAB3B8F4
Authentication : SUCCESSFULL
Erasing address:
>> 01000000 : 0100FFFF
BB_PROGRAMMING_STATUS_REQUEST : 04 FF
ProgrammingStatus_DCT4 : No Error - 0 (0x00)
>> 01010000 : 013BFFFF
>> 013C0000 : 013EFFFF
>> 017C0000 : 017EFFFF
>> 01FC0000 : 01FEFFFF
Erasing Done
Flashing ImageFile
ContinueFlash_DCT4 Complete
Write Time Elapse : 00:00:10
FLASH Mode Set to : PHONEMODE_FLASHBUS
BB_PROGRAMMING_STATUS_REQUEST : 04 FF -- Progamming status
First Byte OK
Second Byte OK
BB_PERM_DATA_RESTORE_REQ : 18 FF
BB_RESTART : 07 FF
MCURestart : SUCCESS
Making delay between files for 6000ms
ImageFile:C:\Documents and Settings\Admin\Desktop\1600_RH_64_Ver_06.93\rh64_0 6.93md
PhoneType : DCT4
> 0120
> 0121
> 1021
> 1120
> 1130
> 1131
> 1201
> 2140
> 2142
> 2201
> 2031
> 2030
> 2032
> 2033
Number of Blocks : 108
Entry Point: 0x00EC
Is128k: True
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
DataLen : 000009D8
Boot OK!
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ExtId0 : 0024
RevId0 : 0111
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
CheckSum : E0
ALGO SENT..
MSID: 84838C5D6C752FC22F180C4938
DecodedMSID: 843E4EBAE900D481A7A8000000
EncodedFAID: 3C69323CF03EB999A34194AB
Erasing address:
>> 011D0000 : 011DFFFF
>> 011E0000 : 0137FFFF
Erasing Done
Flashing ImageFile
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
ImageFile:C:\Documents and Settings\Admin\Desktop\1600_RH_64_Ver_06.93\rh640_ nai6.93md
PhoneType : DCT4
> 0120
> 0121
> 1021
> 1120
> 1130
> 1131
> 1201
> 2140
> 2142
> 2201
> 2031
> 2030
> 2032
> 2033
Entry Point: 0x00E4
Is128k: True
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
DataLen : 000009D8
Boot OK!
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ExtId0 : 0024
RevId0 : 0111
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
CheckSum : E0
ALGO SENT..
Erasing address:
>> 01380000 : 013BFFFF
Erasing Done
Flashing ImageFile
Write Time Elapse : 00:00:00
First Byte OK
Second Byte OK
BB_RESTART : 07 FF
Time Elapse : 00:01:46
Sống trên đời phải Tin và phải biết Tha thứ...
				bạn phải cho cái log info len thì mói biết đc.mình nghĩ do bạn câu chập uem rồi
TRUNG HIẾU MOBILE
				bạn chạy pm chuẩn và unlock cho em nó một phát xem có được không . không đươc thay thử màn hình khác xem sao
Quân đến thì tướng đánh _ Nước mạnh thì đắp đê...!
tất cả mà ko đuoc thì múc luân nguần bác oi
