tình hình e nó bi tím màn dả câu kéo như trên mang mình da search nhưng vẩn not ok thay màn rin dang xài vẩn not ok ae xem dùm cái log rồi cho mình ý kiến ah
 ae xem dùm mình cái log 6100
				MCU SW : V 05.16 26-09-03 NPL-2 (c) NMP.
PPM SW : V 05.16 26-09-03 NPL-2 (c) NMP V
Prd.Code: 0510845
Bpr.Code: 0511917
Prod.Sn : DCE311516
HW Vers : 2965
PCI Vers: 0
UEM : 48
UPP : 4384 [1120]
RFIC Ver: 0300
DSP Vers: 7.90-4.60
LCD Type: SED15G10
IMEI : 351535-00-950000-0
SL Conf : 001-01-00000000000
SL Prof : 000000000000000-2
SL Var : 00553515350095000000
SL Aux : 00020000
Box Id : 8F3DFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
MastCode: 45 11 36 34 07
Provider: GSM Test Equipment
#pw+ 299 945 610 701 051 +1#
#pw+ 923 362 145 175 277 +2#
#pw+ 882 491 104 066 103 +3#
#pw+ 044 003 562 252 215 +4#
#pw+ 048 843 661 620 054 +5#
#pw+ 825 921 240 321 232 +6#
#pw+ 206 565 024 427 375 +7#
				log thì ok rồi .tím màn nhưng nếu nghe gọi ok thì cứ chổ suket mà làm ..kiểm tra lại tất cả các đường coi có thiếu gì không + 2 áp cấp cho nó nữa
				1st Boot: Ok, DCT4, UPP: 1120 [Npl-2] [2.2.0.0]
2nd Boot: u_2nd.fia, Ver: 4.79.0
FlId Aliasing with: 00EC22F0
Fl0: 0x01000000-0x017FFFFF,00EC22F2,Sam K5U64418TM
Algorithm: u_amd.fia, Ver: 4.79.0
Algorithm Ok, MSID: 8437C171652B69FBF032F1FC1C
Decoded MSID: 82A9BAE9-00C318D2-A9000000
Encoded FAID: 20CA390E-C3003250-3D887502
IMAGE: npl2__06.200
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
Area2: 0x01010000-0x0157FFFF Erased, Time: 00:50
Area3: 0x016B0000-0x017EFFFF Erased, Time: 00:11
Area4: 0x01EB0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:58
IMAGE: npl2__06.20u
Area1: 0x01580000-0x016AFFFF Erased, Time: 00:10
CNT Flashing Completed, Time: 00:09
Running: Nokia File Server
CNT Extract Warning, Res: 0, CNT Area not Empty
Contents Package Extracting Ok, Time: 00:07
Algorithm Ok, MSID: 846C6CAA0962341DFFB3CA6B36
Decoded MSID: 82A9BAE9-00C318D2-AA000000
Encoded FAID: 3359D517-82A020C8-07F7BA81
IMAGE: npl2__06.20v
PPM Flashing Completed, Time: 00:11
Flashing Completed, Rebooting Mobile
				Câu chân 9,10 với nhau.not ok đá U cái(ko thì làm chân)
htcantho (01-05-2012)
