Em nó bị trắng treo, không nghe gọi được, bật nguồn không tắt được, đã xóa full và đóng lại upp. xin anh, em chỉ giúp. thanks
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.03
29-06-09
RH-112
(c) Nokia
HW version:
PCI version:
UEM version: 1328
UPP version: 8851
RFIC version: 0700
DSP version: ICPR81_09w22_U
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 04.03
29-06-09
RH-112
(c) Nokia
MR
ADSP SW version: V 04.03\n29-06-09\nRH-112\n(c) NMP\nmr
Production serial number:
Product code:
Module code:
Basic production code:
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 358264036751626
IMEI spare to net: 3A 85 62 04 63 57 61 02
IMEI SV to net: 33 85 62 04 63 57 61 12 F9
Master Code: 1566646267
Failed reading simlock data...
Phone type: RH-112, Software version: 04.03, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-112.ini
Setting local mode...
Reading product code...
Product Code:
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-112\
Checking path: \Products\RH-112\
No ini files found...
Done!
 LinkBack URL About LinkBacks
			 Anh em xem giùm cái log 1202
