tình hình máy bị lỗi con flash em trồng chân đóng lại chạy xong Info nó báo imel ??????
Log nó nè mấy anh !
MCU SW : V 04.03 29-06-09 RH-112 (c) Nokia
PPM SW : V 04.03 29-06-09 RH-112 (c) Nokia MR
Prd.Code: 0562324
Bpr.Code: 0558505
Prod.Sn : DXR198366
HW Vers : 1005
UEM : 1328
UPP : 8851 [2293]
RFIC Ver: 0700
DSP Vers: ICPR81_09w22_U
LCD Type: WIN:SERI:8a NT7542
IMEI : ??????-??-??????-?
SL Conf : 000-00-00000000000
SL Prof : 000000000003000-0
SL Var : 00000000000000000000
SL Aux : 000B0000
HW Sig : BF3C1AE9BF4AA78B
Box Id : FFFFFFFFFFFFFFFF
SL Data Corrupted
Provider: Not Found
Read UEM như vậy nè:
Init Local Mode Failed
Warning, Cannot Read Info from Mobile !
1st Boot: Ok, DCT4, UPP: 2293 [Rh-112] [2.2.0.0]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
Algorithm: u3_st_i.fia, , Ver: 4.79.0
UEM IMEI Num : 351992-04-293316-1
RPL Saved as: 3519920429331611_DATA1_Generated.rpl
Can Use it to Restore Flash Data (UEM not Empty)
Ask IMEI Num : 351992-04-293316-1
Product Code : xxxxxxx
UEM Changed : 0
Dongle S/N : 083309
Algorithm: u3_st_i.fia, Ver: 4.79.0
ASIC Detected: 11
UEM Read Done, Time: 00:01
