<b>
tình hình là máy bình thường thấy máy không có tiếng việt chạy lại phần mềm đang chạy nó mất điện sau đó chay song nó hiện mấy dòng chứ màu đó.máy gọi 1 lúc nhu là mất sóng.lúc gọi được lúc không?mong các bác giúp nó bị j? Backup already exists(C:\mobileEx\3.5\data\backup\XGOLD_RM-713_A85B18F8C4F12C6B_IMEI.back)</b>
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0849028
Using device: HTI, FW ver: 00.50, SN: 0000B75A
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
CFI information:
Flash settings: 0/1, size: 0x01000000
2 Block regions:
255 x 0x00010000 = 0x00FF0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm713_005.370
Downloading item CODE:hw_b1_rm713_r05.370.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.578 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 16.078 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 31.953 s
Error reading checksum!
Processing file: rm713_005.37mr
Downloading item CUST:hw_b1_rm713_005.37mr.fls, num block: 1, size: 5.07 MB
Erasing area 0x00100000-0x0061113E ...OK
Programming completed in 1 min 26.797 s
Checksum mismatch: Phone calculated 0x0062, software calculated 0xC969
Processing file: rm7130_nai05.37mr
Downloading item CUST:hw_b1_rm7130_nai05.37mr.fls, num block: 1, size: 698.08 KB
Erasing area 0x00E60000-0x00F0DB3E ...OK
Programming completed in 11.360 s
Checksum mismatch: Phone calculated 0x00F1, software calculated 0xAE87
Total time for flashing process(boot+erase+write) was 5 min 33.297 s
Phone type: RM-713
SW version: V 05.37 10-08-11 RM-713 (c) Nokia
Imei plain: 35860604244782-3
Product code: 059D900
Cellular system: GSM
