    Thành viên mới nickymobile84's Avatar
    Mặc định 1800 mất nguồn
    anh em xem hộ em cái log con 1800 này, sao vẫn ko lên nguồn.
    Backup saved to "C:\mobileEx\3.5\data\backup\XGOLD_RM-653_88CECA5450AC95CC_IMEI.back"
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0860020
    Using device: HTI, FW ver: 00.50, SN: 00016067
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm653_006.510
    Downloading item CODE:hw_b2_rm653_r06.510.fls, num block: 3, size: 4.14 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 39.562 s
    Erasing area 0x00C60000-0x00E734FE ...OK
    Programming completed in 40.094 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.156 s
    Checksum verified (0xD2D6)
    Processing file: rm653_006.51mr
    Downloading item CUST:hw_b2_rm653_006.51mr.fls, num block: 1, size: 1.90 MB
    Erasing area 0x00210000-0x003F4ABE ...OK
    Programming completed in 36.703 s
    Checksum verified (0xB261)
    Processing file: rm6530_nai06.51mr
    Downloading item CUST:hw_b2_rm6530_nai06.51mr.fls, num block: 1, size: 314.45 KB
    Erasing area 0x00EB0000-0x00EFDCBE ...OK
    Programming completed in 5.984 s
    Checksum verified (0xF7F3)
    Total time for flashing process(boot+erase+write) was 3 min 31.125 s
    After Flash Processing ...
    Reseting Factory Values OK.
    Phone type: RM-653
    SW version: V 06.51 13-05-11 RM-653 (c) Nokia
    Imei plain: 35538604651888-6
    Product code: 0594922
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    - not available.
    Imei net: 35538604651888
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    FULL FACTORY... OK
    Completed in 1.282 s
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 2.172 s
    V.I.P DAKLAK-GSM's Avatar
    Aug 2010
    kiểm tra đo đường màn hình, kiểm tra giao động , nếu không được đá nhe upp cho nó cái
    127 quang trung . phước an. krongpak . daklak
    0982.419.419 yahoo. minhthien883
    Thành viên kỳ cựu dinhhieu444's Avatar
    ĐỒNG NAI
    log done xem rồi đo chân màn hinh xem có tỏng trở không , thay màn hình mới nhe là done
    Thành viên tích cực Tiến Hùng_KTV's Avatar
    Quảng Nam
    Kiểm tra lại đường màn hình nếu good test thử màn khac xem thế nào nhé
    Thành viên tích cực TV.Mobile™_SGM™'s Avatar
    Jun 2012
    ko lên nguồn cứ đem vào chạy chắc ae phần cứng chết đói wa
    TV.MoBile™-YM!:pinky.master205@yahoo.com.vn
  1. 1800 mất nguồn
    By THÔNG THÁI_GSM™ in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 22-08-2013, 12:08
  2. 1800 tự động tắt nguồn
    By tannhut_mobile_bd in forum DCT4 - WD2
    Bài viết cuối: 29-11-2012, 10:27
  3. 1800 mất nguồn
    By vuonglymbcp in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 03-11-2012, 09:24
  4. 1800 hao nguồn
    By moivaonge in forum DCT4 - WD2
    Bài viết cuối: 04-05-2012, 12:52
  5. 1800 hỏng phím nguồn
    By baolinhmobile in forum DCT4 - WD2
    Bài viết cuối: 11-03-2011, 15:07
