tình trạng máy là đang dùng bt ,máy tự mát nguồn,e chay pm chạy gần xong máy báo như sau
\3.5\data\backup\XGOLD_RM-713_A1DCF13E9FCFB413_IMEI.back)
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0874047
Using device: HTI, FW ver: 00.50, SN: 00015B16
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 00EC 2404 - 23280002 [Samsung K5N2833ATM,128 Mbits]
CFI information:
Flash settings: 0/1, size: 0x01000000
2 Block regions:
255 x 0x00010000 = 0x00FF0000
8 x 0x00002000 = 0x00010000
EBL ready !
Processing file: rm713_005.440
Downloading item CODE:hw_b1_rm713_r05.440.fls, num block: 3, size: 5.58 MB
Erasing area 0x00000000-0x00005FFE ...OK
Programming completed in 0.578 s
Erasing area 0x00800000-0x00BEFFFE ...OK
Programming completed in 1 min 13.829 s
Erasing area 0x00C5D000-0x00DFB6FE ...OK
Programming completed in 30.422 s
Checksum verified (0xCD0A)
Processing file: rm713_005.44mr
Downloading item CUST:hw_b1_rm713_005.44mr.fls, num block: 1, size: 5.07 MB
Erasing area 0x00100000-0x006119BE ...OK
Programming completed in 1 min 35.016 s
Checksum verified (0xA0A5)
Processing file: rm7130_nai05.44mr
Downloading item CUST:hw_b1_rm7130_nai05.44mr.fls, num block: 1, size: 698.08 KB
Erasing area 0x00E60000-0x00F0DB3E ...OK
Programming completed in 12.797 s
Checksum verified (0x30AF)
Total time for flashing process(boot+erase+write) was 5 min 28.891 s
