em nhận máy vào sài đc 1 lúc là tự tắt nguôn sông tự mở lên lạ em chạy cho em nó phát h trắng mh
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0874392
Using device: USB Phonet and HTI, FW ver: 00.24, SN: 00015515
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2DBD857A
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI:
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
Processing file: rm702__06.97.mcusw
Downloading item CODE:rm702__06.97.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.328 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.343 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.375 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 34.281 s
Checksum verified (0xA701)
Processing file: rm702__06.97.ppm_v
Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.26 MB
Erasing area 0x41DC0000-0x42300772 ...OK
Programming completed in 6.515 s
Checksum verified (0x5007)
Processing file: rm702__06.97.image_v_059L5S8
Downloading item CUSTackage_v_059L5S8.image.fls, num block: 1, size: 11.88 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 17.187 s
Checksum verified (0xCB72)
Total time for flashing process(boot+erase+write) was 9 min 18.297 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
