    Thành viên mới pEtrAngXinh12's Avatar
    Oct 2012
    Mặc định anh em coi hô em cái x2-01 với
    em kic vào XGOLD flash cái nó báo lỗi không cho chạy bị thế này mấy bác coi hô em dòng nay em chạy nhiều rồi mà quả này không biết bị j nũa
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0874392
    Using device: USB ROM and HTI, FW ver: 00.24, SN: 00015515
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000008F02E2D45DA0FBD2B5CEA06511F7D3
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Loading CMT update server data
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 55B4CAB
    FUR: Adding Asic CMT as client OK.
    ERROR: ReqOutOfSessionDataRead[00000000] failed !
    ERROR: ReqOutOfSessionControl(0x 2, 0x 3, 0x 0, 0x 0) failed !
    ERROR: ReqOutOfSessionControl(0x 2, 0x 4, 0x 0, 0x 0) failed !
    ERROR: ReqOutOfSessionControl(0x 2, 0x 9, 0x 0, 0x 0) failed !
    ERROR: ReqOutOfSessionControl(0x 2, 0x A, 0x 0, 0x 0) failed !
    Original IMEI:
    RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD__back.RPL)
    Bad file format, incorrect magic header of image file !
    Processing file:
    Downloading item USER DISK:, num block: 0, size: 0
    flashing terminated !
    bạn chon một file mcu rồi gỏ vào ô x-gold>>rồi bus check xong quăn cái log lên đây cho ae xem bạn
    Oct 2012
    em nhâm cái này là bb5
    Oct 2012
    ok rồi bác ới tk bác nhé bb5 flash chua đầy 1p ok
    mod đi ngay cho em xin chữ edits
    cu chạy nhủ bb5 bình thuong thôi nha bạn thay cáp thay hộp kak chiên dòng này mình chạy củng nhiêu mà usb ok mà cu làm đi ok
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    ​Chùm Mua..bán.BB5 và androi cũ
    BỘ ngoại giao trùm các 4r
    Thành viên mới khonggian1010's Avatar
    upppppppppppppppppppppppppppppppppppppppppppp
