Kết quả 1 tới 4 của 4
    Thành viên tích cực domdomvang's Avatar
    lào cai
    Mặc định 1200 cần giúp em có cây 1200 sau khi thay nguồn và u cho vao MXKEY
    [MxKey Team HTI PLUS Flasher Interface 1], SN: C087A60C
    Using device: HTI, FW ver: 00.50, SN: 0100D653
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
    FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
    UEM ID: 00C60839A3BDA66
    ASIC type: 11
    UEM Imei: 35686902194378
    Flash Imei: 35293502702286
    Invalid imei checksum !
    Processing MCU file: rh99_05.710
    [DCT4,DCT4 ALGORITHM] size: 2.26 MB
    Supported Ids: 2292
    UEM ID: 00C60839:2984DA60
    Area [01000000-0100FFFF] erased in 1.078 s
    Area [01010000-013AFFFF] erased in 1 min 3.781 s
    Area [013B0000-013EFFFF] erased in 4.422 s
    Area [017C0000-017EFFFF] erased in 0.062 s
    Area [01FC0000-01FEFFFF] erased in 0.078 s
    Flash programming ...
    Programming completed in 13.500 s
    File processed in 1 min 30.031 s
    Processing CNT file: rh990_nai5.71mr
    [DCT4,DCT4 ALGORITHM] size: 110.62 KB
    Supported Ids: 2292
    ExtBUSC: 8020 1000 0000 0000 0000 0004 0000 0010
    Area [01380000-013AFFFF] erased in 3.328 s
    Programming completed in 0.734 s
    Content extract fail, continue anyway ...
    File processed in 1 min 16.938 s
    Processing PPM file: rh99_05.71mr
    [DCT4,DCT4 ALGORITHM] size: 1.13 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 1.094 s
    Area [01250000-0137FFFF] erased in 20.828 s
    Programming completed in 6.890 s
    File processed in 35.890 s
    Total time for flashing process(boot+erase+write) was 3 min 22.859 s
    chay thì nó báo như thế này
    Jun 2008
    Hà Nội & Sài Gòn
    Vẫn là lỗi không đồng bộ . thay upp chuẩn chưa
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Lỗi ở đây,đóng lại ko đc thay upp
    Thành viên tích cực quang_hhbg's Avatar
    Mar 2011
    bắc giang
    lỗi cpu rồi.đóng lại vẫn vậy thì thay con khác.
    quang_hhbg
    01686381111
  1. xin giúp 1200 thay ic nguồn imei ????
    By TÍNH-NGHI_MOBILE in forum DCT4 - WD2
    Trả lời: 17
    Bài viết cuối: 12-09-2012, 20:00
  2. Trả lời: 7
    Bài viết cuối: 18-07-2012, 15:04
  3. 1200 thay upp 2292 mxkey co unlock dươc không?
    By minhhaucv in forum DCT4 - WD2
    Bài viết cuối: 20-01-2011, 10:00
  4. 1200 thay ic nguồn cần giúp đỡ
    By kienhoaimobile in forum DCT4 - WD2
    Trả lời: 18
    Bài viết cuối: 29-11-2010, 08:56
  5. 1200 thay ic nguồn xin giúp
    By phuvietnguyen in forum DCT4 - WD2
    Trả lời: 22
    Bài viết cuối: 10-08-2009, 19:31
