em làm lại rồi log như thế này đc chưa các bác
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087C5B9
Using device: HTI, FW ver: 00.50, SN: 0100E833
Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7600.16385
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 000E3A21A3BDA66
ASIC type: 11
UEM Imei:
35196603244450
Flash Imei: 35196603244450
MasterCode: 6635533265
RPL saved to "C:\mobileEx\3.5\data\backup\35196603244450_BACK.r pl"
Phone type: RH-112
SW version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35196603244450-4
Product code: 0562324
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: MR
Language Pack:
- not available.
Master code: 7737234775
Imei net: 35196603244450
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000003000B
