Kết quả 1 tới 10 của 12
    Thành viên danh dự PhùngMobile's Avatar
    Dec 2011
    Mặc định 6230i Flash báo lỗi !
    1st Boot: Ok, TIKU, UPP: 1052 [Rm-72] [2.2.0.3]
    2nd Boot: te_2nd.fia, Ver: 4.76.0
    Fl0: 0x00000000-0x00FFFFFF,00EC22F8,Sam K8S2815ETA
    Fl1: 0x02000000-0x03FFFFFF,00EC0035,Sam KEE00D00CM
    Algorithm: te_amd_b.fia, Ver: 4.76.0
    Algorithm Ok, MSID: 8409F1BE596BC16D5B80F8CA1A
    Decoded MSID: FE4CBAE9-00D5A3F6-A8000000
    Encoded FAID: 2BD1B454-B9AEDD3B-D2B42FF0
    IMAGE: rm72_73_11003.800
    Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00
    Area2: 0x00010000-0x009FFFFF Erased, Time: 01:39
    Area3: 0x00A00000-0x00B3FFFF Erased, Time: 00:12
    Area4: 0x00B60000-0x00FAFFFF Erased, Time: 00:43
    MCU Flashing Completed, Time: 00:58
    FLASH_FILE_MM_TYPE: TIKU EIJA SSR [NAND]
    Algorithm: te_essr.fia, Ver: 4.76.0
    IMAGE: rm72_73_110E_03.80.ucp_v
    Mass Memory Erased, Time: 00:06
    CNT Flashing Completed, Time: 00:28
    Running: Nokia File Server
    Contents Package Extracting Ok, Time: 00:24
    FLASH_FILE_MM_TYPE: TIKU MON CSM [OneNAND]
    FLASH DEVICE NOT SUPPORTED
    Check Product, Use newer Flash Loader Pack
    Algorithm: te_oncsm.fia, Ver: 4.76.0
    2nd Boot Error:
    Error Data1:
    00000000: 9F 01 04 00 EC 00 F8 22 00 00 11 00 10 00 02 EC ......."........
    00000010: 00 35 00 00 00 00 00 09 00 04 00 00 01 00 00 00 .5..............
    00000020: 00 00 00 00 06 00 00 01 00 00 00 00 00 00 00 00 ................
    00000030: 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 ................
    Error Data2:
    00000000: 11 11 11 11 00 00 00 00 00 00 00 00 00 00 00 00 ................
    00000010: 00 00 00 00 09 00 04 00 00 01 00 00 00 00 00 00 ................
    00000020: 00 06 00 00 01 00 00 00 00 00 00 00 00 00 00 00 ................
    00000030: 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 F7 D3 72 00 ..............r.
    Before taking screenshot, expand this window !
    bị như vậy là sao mọi người
    Yahoo: ptpn701
    Facebook :https://www.facebook.com/phung.austin
    Fone : 09 35 382938
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    đổi qua box khác flash lại xem
    V.I.P Lão_Đại's Avatar
    hải phòng
    (2nd Boot Error: )
    (Error Data1
    Khả năng lỗi HW nhiều , đổi box not OK bạn làm lại em flash coi sao
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    máy lúc đầu bị gì ? nếu máy đang sài mà flash thì kiểm tra lại cáp ..
    nếu máy mất nguồn thì làm chân hoặc thay con gương để coi có nhận ra flash không ?
    Thành viên kỳ cựu nhathuy_mobile2009's Avatar
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    Trích Được post bởi qnmobile123 Xem bài viết
    2nd Boot Error:
    Error Data1:
    Error Data2:
    nếu như không nhầm thì chủ thớt flash nhầm file thì phải ,loại này có 2 file khác nhau nhé ,1 loại E và 1 loại M nhé
    yahoo :nhathuy_mobile2009
    Moderator VanTuan-ST's Avatar
    Nov 2007
    Sóc Trăng
    Dòng này có 2 loại chip : E & M, nếu của chủ thớt thuộc chip M new H/W thì load file này về flash.
    03.89 new hw.rar
    Dec 2011
    Trích Được post bởi VanTuan-ST Xem bài viết
    03.89 new hw.rar
    máy không bị gì hết, chỉ bịt trắng màn hình thôi anh à, mà em chạy như thế xong bật nguồn lên, nhận cuộc gọi đến bình thường là sao nhỉ
    Yahoo: ptpn701
    Fone : 09 35 382938
    Nov 2007
    Sóc Trăng
    Vậy máy bạn chip M rồi
  9. ( VanTuan-ST ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    PhùngMobile (14-03-2013)
  10. #9
    Dec 2011
    Chip M thi phai chạy lại file anh mới update hả anh
    Yahoo: ptpn701
    Fone : 09 35 382938
  11. #10
    Dec 2011
    e chạy file của anh VanTuan cũng vậy nè
    Algorithm Ok, MSID: 845D8851D4A82F658B3AA3108E
    Decoded MSID: 80B0BAE9-00D5A3F6-A8000000
    Encoded FAID: C0206583-53BD525C-6C37EEC3
    IMAGE: rm72_73_11003.890
    Area2: 0x00010000-0x009FFFFF Erased, Time: 01:42
    2nd Boot Error:
    Error Data1:
    Error Data2:
    2nd Boot Error:
    Error Data1:
    Error Data2:
    Yahoo: ptpn701
    Fone : 09 35 382938
  1. 6230i Flash báo lỗi
    By THÔNG THÁI_GSM™ in forum DCT4 - WD2
    Bài viết cuối: 09-09-2011, 18:26
  2. 6230i flash không được
    By jacky2007 in forum J.A.F
    Bài viết cuối: 13-01-2010, 22:43
  3. flash của 6230i
    By phone_lucky in forum BB5
    Bài viết cuối: 30-11-2009, 23:36
  4. 6230i bị chết flash bộ sưu tập ??? help me ?
    By hoangnam81mobile in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 06-08-2009, 22:50
  5. 6230i flash bị contacservic
    By haugiang in forum DCT4 - WD2
    Bài viết cuối: 17-04-2007, 10:30
