em có con 1280 bị chết nguồn chạy phần mềm nó ko đồng bộ được
em đã đóng lại cặp và thay thạch anh nhưng vẫn ko được
bác nào gặp qua giúp em vơi em cảm ơn
đây là log của nó các bác giúp em với
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm647_006.510
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 5EF5
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2069312 bytes
Data Checksum: F587
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm647_006.51mr
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x003288BE
Start Erasing...
Block Erase Done...
Data Size: 1149120 bytes
Data Checksum: 0715
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm6470_nai06.51mr
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00EFBA3E
Start Erasing...
Block Erase Done...
Data Size: 309824 bytes
Data Checksum: D0A1
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:28
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
