MCU ID: 0x2201
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
First 16 bytes: AD BB 22 08 01 0A 0A 62 49 08 09 C4 41 0E 25 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Detected P-KEY: 90009699
Changing mode...Done!
Changing mode...
Failed!!!
Phone Type:
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-93\RH93_0515046_7.02_001\VariantConfiguration\0515 046.xml
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-93\RH93_0515046_7.02_001\VariantConfiguration\0515 046.xml
Booting phone...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-93\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-93\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
Languages in ppm: English,Chinese S,Chinese T
Failed! Aborting!
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
Booting phone...
MCU ID: 0x2201
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Boot size is 0x09A0
Boot is ready...
First 16 bytes: FE 5A 0E 8B 9F A4 50 B6 44 FA 8A 5C E2 8B 44 AB
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
Loader size is 0x5538; Loader chk: bb
Loader is ready...
MSID: 84ED6885A9BD116EB92811866C
MSID decoded: 3E4EBAE900071ABAAA000000
FAID: 18EA1ACB2A7DFD1310366CDE
Erasing...
Found 5 interval(s) to erase
Erasing area: 01010000 - 013BFFFF...
Erasing area: 013C0000 - 013EFFFF...
Operation took 0 minutes 40 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 17 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02qa
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
MSID: 8421029F043CC01681154096AE
MSID decoded: 3E4EBAE900071ABAA8000000
FAID: 0A2D4996F659DD69EAA1F828
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 011E0000 - 011EFFFF...
Erasing area: 011F0000 - 0137FFFF...
Operation took 0 minutes 16 seconds...
Writing...
Operation took 0 minutes 11 seconds...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02qa
Booting phone...
MCU ID: 0x2201
Boot size is 0x09A0
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Erasing area: 01380000 - 013BFFFF...
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Flashing Done!
Operation took 2 minutes 14 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
