thank may ban nhiều mình đang chờ kết quả
minh nap roi no báo như thê này
Selected PM File: C:\AdvanceBox Turbo Flasher\Nokia\Backup\MMC_PASSWORD__92218.pm
Start Uploading PM...
MCU: V 06.51 13-05-11 RM-647 (c) Nokia
IMEI: 351927053441936
Product Serial Number: 74C77C7AH
Product Code : 0592248
Module Code : 0204496
Basic Production Code: 059J889
PPM SW Version : V 06.51 13-05-11 RM-647 (c) Nokia MR
ADSP Version : p V 06.51\n13-05-11\nRM-647\n(c) NMP\nmr
MCU SW Version : V 06.51 13-05-11 RM-647 (c) Nokia
HW Version : 1004
UEM Version : 1328
UPP Version : 8850
LCD Version : UNKWN: IDs: 00:00:00
********** SIMLOCK INFO **********
CONFIG_DATA : 0010100000000000
PROFILE_BITS : 0000000000030002
ASIC : 11
PROVIDER : Default Test Operator
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
ST_LCD_TEST : FAILED
Phone Cannot Enter Normal Mode if LCD
is Damaged or LCD is not Properly
Connected to the Main PCB
Field : 302 Sub : 0 Byte(s): 36 - Failed
Field : 302 Sub : 1 Byte(s): 148 - Failed
Field : 302 Sub : 2 Byte(s): 148 - Failed
Field : 302 Sub : 3 Byte(s): 148 - Failed
Field : 302 Sub : 4 Byte(s): 148 - Failed
Field : 302 Sub : 5 Byte(s): 148 - Failed
Field : 302 Sub : 6 Byte(s): 148 - Failed
Field : 302 Sub : 7 Byte(s): 148 - Failed
Field : 302 Sub : 8 Byte(s): 148 - Failed
Field : 302 Sub : 9 Byte(s): 148 - Failed
Field : 302 Sub : 10 Byte(s): 148 - Failed
Field : 302 Sub : 11 Byte(s): 148 - Failed
Field : 302 Sub : 12 Byte(s): 148 - Failed
Field : 302 Sub : 13 Byte(s): 148 - Failed
Field : 302 Sub : 14 Byte(s): 148 - Failed
Field : 302 Sub : 15 Byte(s): 148 - Failed
PM Upload Done!...
vai bac noi tre qua lam luon roi
bơi vậy đó bác ơi máy dao đông tốt mà mở nguồn thì kim dồng nhích lên xuống em đả đống lại cpu thay tụ trở gần chân pin flash roi nạp pm ròi thử màn hình khác ròi mà em nó vẩn thế
Thay cắp mới thôi![]()
Call: 0933 208986
(.)(.) + Silicon = ( . )( . )
