mới nhận của khách 1 con máy đang dùng tự nhiện sập nguồn.thấy dao động bình thường e kiểm tra chân màn hình bình thường.xong bỏ chạy lại pm thì bây giờ treo kim 0.01a e chạy lại lần nữa và log đây ai giúp e với
VBATT Powering Down <<<<
VBATT Powering Up >>>>
SET VCCIO Level Done
SET BSI Load Done
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 19456 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: STMicroelectronics
Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_007.000
Data Block Found...
Number of Sections: 03
IMAGE Certificate Block Sent Successfully...
Processing Section 01 of 03
IMAGE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: FC95
Uploading Data Blocks to phone...
IMAGE Data Blocks uploaded to phone...
Processing Section 02 of 03
IMAGE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2073472 bytes
Data Checksum: 1426
Processing Section 03 of 03
IMAGE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_007.00mr
Data Block Found...
Number of Sections: 01
Processing Section 01 of 01
IMAGE Erase Block: 0x00210000~0x00328AFE
Start Erasing...
Block Erase Done...
Data Size: 1149696 bytes
Data Checksum: DB5A
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai07.00mr
Data Block Found...
IMAGE Erase Block: 0x00EB0000~0x00EFB43E
Start Erasing...
Block Erase Done...
Data Size: 308288 bytes
Data Checksum: 1957
Exit Flash Mode Done...
Time Elapse : 00:02:22
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
