con này nạp rất lâu nên đừng sót ruột lúc nào nó báo xong thì thôi.
0985210545
Download file chuẩn đúng code múc sẽ done.
card found: A1B5CCE8
registered to: CycloneBox
Connect phone on selected interface...
Core : v1.51 , FlashEngine : v2.01
Insert cable in to powered OFF phone! (Ignore if phone Connected)
Waiting for NOLO...
Connect in NOLO mode Ok!
Phone Info :
Type : RM-696 , HWRev : 1604
NOLO : 01/06/23
SWVer: DFL61_HARMATTAN_40.2012.21-3_PR_001
Device mode : Production mode
Read info Ok
Processing APE Boot...
File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
Processing : ape-algo
APE Algorithm boot Ok
Reopening the connection...
RFS mode init Ok
Device : RM-696
HW build : 1604
Bat.level : 86
SW release : (empty)
Protocol : 108
UPDAPP ver : 1.7.2
Upd/Dev PT : 3 , 3
FL_images : cert-sw,xloader,secondary,rootfs,kernel,moslo,config,mm c,tar,cmt-2nd,cmt-algo,cmt-mcusw
Last errors : bb5_rdc_cert_read failed
Code Match Ok
HW match Ok
RFS : Performing SWAP WIPE...
Starting Wipe...
Bat.level : 86
Battery voltage is enough, starting wipe...
Formatting... Can take up to 15-50 minutes, wait until process complete
Do not disconnect phone, until done!
RFS : Swap format Ok
RFS : No any errors
RFS Set : Host Protocol set to 108
RFS Set : CMT Verify On
RFS Set : Perform RFS On
RFS Set : eMMC preserve On
---Processing MCU image---
Processing File : DFL61_HARMATTAN_40.2012.21-3_PR_LEGACY_005-OEM1-958_ARM.bin
RFS : Sending config for [cert-sw]
-> Ver T : RM-696
-> Ver H : 1507 , 1508 , 1509 , 1510 , 1601 , 1602 , 1603 , 1604 , 1605 , 1701 , 1702 , 1703 , 1704 , 1705 , 1801 , 1802 , 1803 , 1804 , 1805
RFS : Init pipe 00
RFS : Flashing...
RFS : Finalizing...
cert-sw Flash done
RFS : Sending config for [kernel]
-> Ver I : 2.6.32-20121301+0m8
RFS : Init pipe 01
RFS : Flashing...
RFS : Finalizing...
kernel Flash done
RFS : Sending config for [rootfs]
-> Ver I : DFL61_HARMATTAN_40.2012.21-3_PR_005
RFS : Init pipe 02
RFS : Flashing...
RFS : Finalizing...
rootfs Flash done
RFS : Sending config for [cmt-2nd]
-> Ver T : RM-696
RFS : Init pipe 03
RFS : Flashing...
RFS : Finalizing...
cmt-2nd Flash done
RFS : Sending config for [cmt-algo]
-> Ver T : RM-696
RFS : Init pipe 04
RFS : Flashing...
RFS : Finalizing...
cmt-algo Flash done
RFS : Sending config for [cmt-mcusw]
-> Ver I : 9.2.2011.51
-> Ver T : RM-696
RFS : Init pipe 05
RFS : Flashing...
RFS : Finalizing...
RFS : ERROR_PIPE_FINAL_REQ FAILED
Receiving error list...
Last errors : MTC_POWER_OFF not received
CMT RFS failed
[Pipe 5] Finishing in error state with status 1
Flashing failed
More info in Last Error Log
Elapsed: 00:21:48
lỗi này là lỗi gì à các anh.
Chưa có gì để cả.
à rồi. đã done. em đã flash lại bằng slasher và ok. nhưng nó báo là cài đặt mạng di động không thể dùng. lỗi thẻ sim. là thế nào thế các sư phụ. máy lock chăng. ban đầu nó cũng bệnh như trên nên em mới flash lại và bị die. main còn đẹp long lanh.
Chưa có gì để cả.
sim hư-->máy không nhận sim chăng
thay cả chục cái rồi xếp ơi. khả năng lock mạng
Chưa có gì để cả.
máy đã trả khách. admin close pic dùm. thông báo thêm là chỉ nạp cho nó lên nguồn thôi. còn sim thì chịu. máy malai. không có box zịn nên trả luôn. không nhiều người lại bảo không chia sẻ. ok
Chưa có gì để cả.
