Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514
Module ver: 1.0.0.21762(03-12-2014), Library ver: 1.0.0.14473(03-12-2014)
RPL backup already exist (C:\mobileEx\3.5\data\backup\35621600027479_BACK.r pl).
Processing MCU file: rm13_33_11003.780
[TIKU BT2,TIKU ALGORITHM] size: 9.86 MB
Supported Ids: 1052, 2051
ASIC ID: 0x1052 [TikuEdge ver: 1.1]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0020 [Samsung KFM1216Q2M,512 Mbits] type: NAND hw: EIJA(E)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
UEM ID: 00426F71:BDB3DA60
Area [00000000-0000FFFF] erased in 0.630 s
Area [00010000-009FFFFF] erased in 1 min 38.652 s
Area [00A00000-00B3FFFF] erased in 12.373 s
Area [00B60000-00FAFFFF] erased in 43.524 s
Flash programming ...
Programming completed in 1 min 7.835 s
File processed in 3 min 52.330 s
Processing CNT file: rm13_33_11003.78.ucp_x
[TIKU BT2,TIKU MON CSM] size: 4.66 MB
Supported Ids: 1052, 10C6, 2051
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
The semaphore timeout period has expired
Error while programming [2E] at 0x01000020, Result: 0000
flashing terminated !
dến đây nó lỗi là sao vậy ae
