Anh em nào gặp trường hợp này chưa chỉ giáo dùm
máy 2626 bị rớt nước cham nguồn.xong em thay IC nguồn mới, sau đó gắn hộp vào Boot Ok, chạy flash giữa chừng thì báo:
VBat is 3.89V
Vpp pin has 1.28V, Connected
Pins:
Mbus 1, Box Tx 1, Box Rx 1, Bsi 0
Boot...
DCT4
u_2nd.fia
u_amd.fia
ASIC ID: 2031
Configuration Info (9F):
Number of Flashes: 2
01000000: Samsung, 00EC 22E8 0000 7121, 10
02000000: NotUsed, 0000 0001 0000 0000, 0
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
UEM IMEI is: 35807101055412
============= Set FBus mode for info =============
VBat is 3.90V
Pins:
Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
============= Set Flash mode for info =============
VBat is 3.90V
Pins:
Boot...
DCT4
u_2nd.fia
u_amd.fia
ASIC ID: 2031
VBat is 3.89V
Pins:
Using Tx2 Data line.
Processing File: rm291__03.51.image_v
Boot...
ASIC ID: 2031
DCT4
u_2nd.fia
u_amd.fia
844C1E35388EFC8D9860A9515249
Erase[3.37 MB]...
erasing region [01B80000 to 01EDFFFF]
in 23.14s
Flash[1.20 MB]...in 6.19s
* * Processed file in 38.92 seconds
* * * Phone flashing done in 0:39 minutes
Post Flash serial tunning of phone....
Pooling mode for full factory set...
Phone not responding, try to set manually!
Boot...
ASIC ID: 2031
DCT4
u_2nd.fia
u_amd.fia
Erase[3.37 MB]...
in 23.27s
Flash[1.20 MB]...in 6.20s
* * Processed file in 39.03 seconds
Ape flashing not completed yet...
