Kết quả 1 tới 8 của 8
    Thành viên chính thức xuanmobile's Avatar
    Dec 2007
    Thumbs down 1600 rớt nước xin giúp
    em có cây 1600 rơi nước em dã đóng lại cu chạy bằng jaf máy thế này bị gì mới huynh
    MCU ID: 0x2201
    FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    P-key nokia module version 01.01
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_05.540
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_05.54aa
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai5.54aa
    Languages in ppm: English,Dannish,Norwegian,Swedish
    Phone Type:
    Phone Type:
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_05.54md
    Languages in ppm: English,Filipino,Vietnamase
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai5.54md
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_05.540
    Booting phone...
    MCU ID: 0x2201
    BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
    Boot size is 0x09A0
    Boot is ready...
    Flash ID is 0x6822EC00
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
    Loader size is 0x7518; Loader chk: 21
    Loader is ready...
    MSID: 84A3500FDE4839EA0C526330E5
    MSID decoded: 3E4EBAE900D13287AA000000
    FAID: F016854578A58C5F5B6C535F
    Operation took 0 minutes 15 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 22 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 12 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_05.54md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011D0000 - 011DFFFF...
    Erasing area: 011E0000 - 0137FFFF...
    Operation took 0 minutes 9 seconds...
    Writing...
    Operation took 0 minutes 11 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai5.54md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    MSID: 84300404DB7D8C4B3DD95CBCE1
    MSID decoded: 3E4EBAE900D13287A8000000
    FAID: 2F57692A6F84C333BB612F3C
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 1 minutes 46 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Thành viên mới Duong_Hn_Mobile's Avatar
    Jan 2008
    gjfsjhfdhjshjjdfjhgkhs
    Moderator nguyen's Avatar
    Oct 2006
    BẠC LIÊU
    Trích Được post bởi xuanmobile Xem bài viết
    MCU ID: 0x2201
    Algo is ready...
    Done!
    Phone Restarted...
    Phone Type:
    Phone Type:
    Phone Type:
    Phone Type:
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Writing...
    Restarting MCU...
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    Loader is ready...
    Writing...
    Restarting MCU...
    Flashing Done!
    Failed! Aborting!
    Flash oki nhưng info có ra gì kg?
    Trích Được post bởi Duong_Hn_Mobile Xem bài viết
    MEMBER KG DC SPAM.
    HẠNH NGUYÊN MOBILE.
    Thành viên chính thức dangquangbmt's Avatar
    còn hộp nào khác không cho qua chạy thử xem sao
    Dec 2007
    ko in for được bác ah
    V.I.P sybenlove's Avatar
    Oct 2007
    ko info dc thì xem con nguồn có đóng keo ko , nếu đóng keo thì chơi nguồn , nếu ko thì thay con cpu luôn , máy vô nước ít khi bị mất nguồn do phần mềm lắm
    Hoàng Tuấn mobile
    gò dầu/ Tây Ninh
    V.I.P thuybinhthuan's Avatar
    Apr 2006
    theo mình con cpu của bạn gần chết rồi đấy. kiếm con khác thay thử rồi flash lại xem
    có lẽ nào em ngây ngô không hiểu, rồi một ngày ,rồi một ngày sỏi đá củng thành cơm...
    Thành viên mới phamtuan_nokia's Avatar
    Mar 2008
    theo mình nên thay cpu là đúng rồi đấy
    PHẠM TUÂN mobile TRUNG TÂM SỬA CHỮA BẢO HÀNH DTDD.DC.ĐÔI 3 HẢI LẠNG TIÊN YÊN QUẢNG NINH DT 0904071086
  1. 3g mắc lổi 1600 cần giúp
    By mainhancon in forum iPHONE 3G
    Bài viết cuối: 08-01-2013, 09:41
  2. 1600 cần giúp đở
    By vanthidn in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 25-06-2009, 14:17
  3. Đèn màn hình 1600 kì lạ xin giúp
    By LONG_MOBILE in forum DCT4 - WD2
    Bài viết cuối: 13-04-2009, 21:13
  4. 1600 mất đèn cần giúp
    By rap_3g in forum DCT4 - WD2
    Bài viết cuối: 13-03-2009, 13:11
  5. 1600 Rât Cần Sự Trợ Giúp
    By luongno in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 02-08-2007, 09:12
