Kết quả 1 tới 7 của 7
    Thành viên chính thức AK47's Avatar
    Dec 2007
    Mặc định N 6230 bệnh lạ
    Mình nhận 1 con N6230 kẹp thử nguồn thấy chớp chớp màn hình. Cho vào J.A.F test thử vẫn Ok nhưng không lên nguồn. Mình chạy lại nó báo như thế này : Nhờ anh em trong diễn đàn trợ giúp. Thank's
    Getting MCU ID
    MCU ID: 0x1052
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Failed! Aborting!
    Backup IMEI zone...
    Setting local mode...
    Reading IMEI...
    Failed! Aborting!
    Getting MCUID...
    MCU ID: 0x1052
    Reading flash chip detailes...
    MCU ID: 0x1052
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 00000000 - 00FFFFFF...
    Done!
    Erasing area: 02000000 - 02FFFFFF...
    Done!
    Erasing area: 04000000 - 04FFFFFF...
    Done!
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.500
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.50t
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.50.ucp_t
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.500
    Booting phone...
    MCU ID: 0x1052
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x22F800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 38
    Loader is ready...
    MSID: 84F249440E7225D0BA9D288E10
    MSID decoded: B03FBAE9000015A8A9000000
    FAID: F5BB44B61EE89305B3D8ECF0
    Operation took 0 minutes 15 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 007FFFFF...
    Erasing area: 00800000 - 0093FFFF...
    Erasing area: 00B60000 - 00FEFFFF...
    Operation took 2 minutes 12 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 51 seconds...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.50.ucp_t
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 841F050FBC9F4E583DC8C93A72
    MSID decoded: 3E4EBAE9000015A8A8000000
    FAID: C3C81C23CC3B63F52700F2C4
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 00940000 - 00B3FFFF...
    Operation took 0 minutes 20 seconds...
    Writing...
    Operation took 0 minutes 9 seconds...
    Restarting MCU...
    Extracting Content Pack...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\Products\DCT4\rh-12\rh12_28_11005.50t
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 840CA2B60A5832C6B9D35F0A09
    MSID decoded: 3E4EBAE9000015A8AA000000
    FAID: 49A35054D76F4F7A0476ADA9
    Operation took 0 minutes 16 seconds...
    Erasing PPM...
    Operation took 0 minutes 19 seconds...
    Writing...
    Operation took 0 minutes 10 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 7 minutes 5 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Failed! Aborting!...IMEI
    V.I.P anhdaomobile's Avatar
    Oct 2007
    CP Extract Failed!
    xóa flash + nạp FULL + UNLOCK
    Anhdaomobile Service Phong Điền TPCT 0902040487
    Unlock Nokia-Samsung-Moto-Sony- Nạp tiếng việt SS SoftBank - China - LG
    V.I.P GSM Hải Phòng's Avatar
    Nov 2007
    Haiphonggsm.vn
    xóa full đi nạp lại ver cao chút ok thôi mà
    MINH KHÔI - CHUYÊN CUNG CẤP SỈ & LẺ CÁC THIẾT BỊ CHẠY CHƯƠNG TRÌNH
    Mobile: 0982.572.666 YM Cendy_tuongvy2008
    Dec 2007
    Mình xóa full rồi nạp V 5.50 rồi nhưng vẫn vậy. Anh em nào có V cao hơn gửi cho mình nhé !
    Thành viên tích cực HưngMobile's Avatar
    Thốt Nốt_Cần Thơ
    xóa flash ,nạp FULL ,UNLOCK.không đươc thì kiểm tra R đường BSI nhé
    Oct 2007
    Trích Được post bởi trinhquochung Xem bài viết
    đúng r k thì xem lại cái ổn áp
    Dec 2007
    Thank các bác nhé ! Kiểm tra lại rồi nhưng vẫn vậy.
    Giang hồ hiểm ác anh không sợ
    Chỉ sợ đường đời thiếu vắng em.
  1. Trả lời: 21
    Bài viết cuối: 24-10-2008, 09:38
  2. 6230 của em mất míc...
    By vaodoi in forum DCT4 - WD2
    Bài viết cuối: 14-09-2008, 08:10
  3. 6230 cua e la k cac bac ne!
    By dungnv86 in forum DCT4 - WD2
    Bài viết cuối: 30-08-2008, 10:35
  4. 6230 mất mic
    By thekien in forum DCT4 - WD2
    Bài viết cuối: 31-12-2007, 23:54
  5. 6230 bệnh của 6230
    By GSMBT in forum DCT4 - WD2
    Bài viết cuối: 21-12-2007, 09:09
